Where Can I Buy Jute Strap In Kingston, Ontario? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-04-2014, 10:14 AM   #1
Rewards Points: 12
Where can I buy jute strap in Kingston, Ontario?
I've got a couple of old chairs for my office that have 1 3/4" strapping on the seat that need replacing. Looking around, it looks like jute is the best option (I've tried marine fiberglass strap, which was the best option available within walking distance, and that was a disaster!).
Where do you get it, though? Should I be looking in hardware stores or fabric stores?
PantsMasterson is offline   Reply With Quote
Old 08-04-2014, 12:50 PM   #2
Rewards Points: 12
Check in Upholstery Fabric or Arts and Crafts stores if you want to source it locally. But, be forwarned that Jute upholstery webbing, also sold as burlap webbing, is a specialty item. You will probably end up having to mail order it. If I can't order it directly from the weaving house, I tend to default to Amazon.
I don't work much with straps and webbing, but use a lot of 1/4"-1/2" diameter rope for outdoor knotting and rigging projects. I usually end up making the heavier ropes out of twine via
usscouts.org/scoutcraft/BoyScoutRopemaking.pdf
But using a power drill and an eyebolt with an opening cut into it instead of a rope spinner.
EyeballEngineer is offline   Reply With Quote
Old 08-10-2014, 05:21 PM   #3
Rewards Points: 2,166
Best bet would be online.
Startingover is online now   Reply With Quote
Old 10-30-2014, 01:43 AM   #4
Rewards Points: 108
Yeah, you should check online stores once. Otherwise, check your nearest art and craft shop, you may get good and stylish one.
RobertCurry is offline   Reply With Quote
Strap for wall light pex006 Electrical 1 03-19-2014 02:13 PM
General Question about Ontario Code/Inspections ChantryOntario Electrical 2 04-27-2013 08:53 AM
How to Replace Wall Sink Drain Rod & Strap MplsJJ Plumbing 4 11-21-2011 04:23 PM
Basement handrails in Ontario - help! navaidstech Carpentry 13 09-26-2011 06:30 PM
hi everyone, new homeowners from Kingston, ON Canada ajsheri Introductions 0 07-31-2010 12:34 PM
