What Type Of Glue? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-02-2009, 07:01 PM   #1
What type of glue?
Hi,
I am doing a Nascar theme in my son's room and would like to make a tire rimmed mirror. I have a real Nascar tire that I will be cutting the face out of for the frame. I purchased a plexiglass type of mirror material, that I will attach right to the tire in the tire lip (16" round exactly).
What type of adhesive would I use to adhere plastic to rubber?
Any help would be greatly appreciated. Thanks.
edrichard is offline   Reply With Quote
Old 06-03-2009, 09:39 AM   #2
RippySkippy's Avatar
A few spots of clear silicone, trim the excess when dry.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-05-2009, 06:40 AM   #3
Good luck! with decorating your son's room. I heard 3M Scotch-Grip adhesive is good for perfect sturdy bonding.
Dana
Dana11 is offline   Reply With Quote
Old 06-05-2009, 07:56 AM   #4
the Musigician
DangerMouse's Avatar
personally, i'd go with PL construction adhesive.
DM
Old 06-05-2009, 08:44 AM   #5
Say it Is not so!!!!
As Rippy Skippy has stated, Clear Silicone will do the job splendidly!!!
It is nearly invisible when dry.
It is easily managed during the cure time.
It is easily trimmed where there may by bleed-out.
It holds fast and long!
MALCO.New.York is offline   Reply With Quote
Old 06-06-2009, 12:06 AM   #6
Haste Makes Waste
Clear silicone is an excellent choice. You may also consider some of the Loctite bonding agents. They have an adhesive (anerobic) for just about any application imaginable.
By the way...aquariums are held together with clear silicone. Pretty strong stuff when you consider a gallon of water weighs 8.4 lb and even a small aquarium is 10-20 gallons. That's a lot of weight pressing against the glass sides.
saggdevil is offline   Reply With Quote
Old 06-06-2009, 06:26 AM   #7
the Musigician
either will do fine, i make fishtanks too..... personally, i'm more curious what you will use to cut up the tire?
DM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 03:16 AM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
Laminate flooring over old glue?? TomC723 Flooring 2 08-19-2008 01:33 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 12:56 PM
