Well Made Slim Under-cabinet Lighting For Kitchen? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-01-2013, 12:09 PM   #1
Rewards Points: 248
well made slim under-cabinet lighting for kitchen?
I would be grateful for some recommendations on under-cabinet lighting for the kitchen.
must-have features:
well-made not flimsy
direct-wire (not plug-in, not requiring an external power adapter)
warm white light without a bluish tint
slim profile ( about 1" thick, give or take a bit)
screw-mounted directly to the underside of cabinet or that would clip onto rods that are mounted to the underside of the cabinet
Nice to have features:
lights can be "aimed"
can be daisy-chained
available in several lengths including a small one around 10-11 inches.
Thank you.
diy888 is offline   Reply With Quote
Old 09-01-2013, 12:42 PM   #2
Rewards Points: 274
Nice recommendations.
alexjoe is offline   Reply With Quote
Old 09-01-2013, 01:07 PM   #3
Rewards Points: 248
Thanks. I cannot see the recommendations and am getting an error message that my browser is unable to resolve the IP address. Was it copied and pasted from a Google Ads search by any chance? My browser has a "stealth" feature that turns Google Ads and Google tracking off.
Or were you commenting on the features I wanted? :-)
Old 09-01-2013, 02:29 PM   #4
K&B Designer
Live_Oak's Avatar
I'd recommend re-evaluating your wish list.
I use Hafele LED tape lighting for all of my cabinet designs and it will do all but 2 of your wish list. It's not "aimable", but in 30 years of design, I have never needed that ability for UC lighting, so I'm not sure why you would. The other is that it requires a transformer, or what they call, a driver, as any low voltage lighting requires. That makes it extremely easy for anyone to install this lighting as all you need is an outlet to plug the transformer into. If you place that outlet above the cabinets, everything is hidden, and it all works extremely well. The warm LED lighting really complements wood tones in the cabinetry It can be dimmed, be switched by a motion sensor, or a standard on/off switch.
I use it for in cabinet lighting, on the back of the face frame, or for open cabinets, as well as under cabinet lighting. It's extremely low profile (1/8") and extremely low energy use have made all other types of lighting obsolete, IMHO.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
oh'mike (09-01-2013)
Old 09-01-2013, 04:55 PM   #5
Rewards Points: 248
Light-switch in our 33.5-inch (custom-sized) Broan range-hood exhaust-fan broke and it costs hundreds of dollars and a big headache (complete disassembly) to replace. So I want to "aim" the light onto the cooktop below, from the side.
No such outlet above the cabinet and no easy way to put one there, since the cabinets go up to the ceiling and it's brick-wall behind.
I like the extremely low profile of the lights, and that they are "warm". But what is the profile of the transformer, and can it be wired directly to the incoming voltage line, rather than plugged in to a receptacle?
Old 09-03-2013, 04:14 PM   #6
K&B Designer
Live_Oak's Avatar
Fix the hood light. You're attempting to do something with UC lighting that it's not really meant to do, even though I think every kitchen needs UC lighting. It's not meant to replace the light from a hood, nor to stand up to the heat and steam that cooking produces.. A generic switch from some place like Johnstone is probably less than $20. An electrician or good appliance repairman could probably diagnose and fix the hood fairly cheaply.
Wiring old medicine cabinet with fluorescent lighting okieopie Electrical 9 05-11-2015 09:51 AM
Wiring for under cabinet lighting fredm54 Electrical 15 06-16-2012 01:23 PM
Hard wiring under cabinet lighting demandrew Electrical 14 02-24-2012 10:31 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
Help! Our contractor made our kitchen cabinet door stain TOO ORANGE! Nikki99 Painting 12 11-20-2007 12:45 AM
