Wanting To Finish Basement
I have now saved enough money to finish my basement and I need ideas. I want to do something rustic. I have already bought my flooring which is bridgeport red oak. I have access to alot of cedar boards also. Would they go together? Basement is 31x27. I'm new here and really needing ideas. Want to do some of the walls in lumber some drywall and painted, Maybe half wall with ledge. Any help would be appreciated as I'm "Green" when it comes to this type stuff. Thanks!
Too vague, too many options.
how much money have you saved?
Wood is not a good choice for most basements. If you must do wood floors, lay a subfloor first. Maybe use cedar for some sort of storage closet? Use mold-proof sheetrock for walls.
I'm doing my basement in a cabin/small house in the N GA hills. It is only a bit larger than yours.
I'm going for a looks that's not quite as rustic as yours but still with a cosy cabin flavor (I hope). I'll have a beam over the center of the large front room and 2 post on the side supporting it. They'll trim out in pine and then do a warm stain that'll be a darker cherry look I think. I talked to a few flooring places about what I could use and they all recommended a floating floor (laminate). Maybe some of the cedar could be used as trim or trim over a beam? |
error, sorry
| All times are GMT -4. The time now is 08:38 AM. |
