Want Less "faux" In My Bricks - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-13-2011, 12:42 AM   #1
Want less "faux" in my bricks
I'm looking for faux brick paneling to put on my office wall. I want something really rustic, Chicago-ish brick type, but any brick panels I've seen have looked more faux than brick. I can find faux stone that's beautiful ... but where is the brick that doesn't look like it came fresh out of the '70s Bewitched living room?
phunketernity is offline   Reply With Quote
Old 10-16-2011, 05:47 AM   #2
m1951mm's Avatar
I am attaching a pic of a faux block wall I did in my office. The process is not that difficult if you are somewhat familiar with a trowel, level, and glazing. If you like the look I can walk you through the process. The materials are not cheap but look great.
Want less "faux" in my bricks-faux-block-004.jpg   Want less "faux" in my bricks-faux-block-002.jpg
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 10-17-2011, 05:02 PM   #3
Too Short? Cut it Again!
See if the library has the "Recipes for Walls" series about faux finishes. The library should have other books on faux paint finishes as well.
Your other option is to use real thin brick veneers. They are thin but look quite nice and like real brick (because they are but are not structural) once you grout them. You place them over a panel system with adhesive in running patterns just like real brick and then mortar the joints. You can even send your own brick selection to be cut if you do not like any of the bricks you find in stock. This is one company. There are others.
Using the right bricks for firepit? abbyqueue Landscaping & Lawn Care 2 08-16-2011 06:11 PM
Bricks for Underground Application jsbeckton Building & Construction 2 05-25-2011 11:09 AM
Moved Foundation Bricks and Hollow spot? yellowhouse Building & Construction 3 09-28-2010 08:43 AM
Reclaimed Bricks (repointing) soft? davidwarner Building & Construction 11 05-06-2010 09:56 AM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
