Wallpapering Round Corners - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-14-2008, 01:51 PM   #1
Question
wallpapering round corners
hi,
i am having a problem wallpapering round the corners of my bedroom. the corners are not square to the wall. when i hang the paper around the corners the edges of the paper are not virtical on the wall . has any body any idea to overcome this problem.
johnbrk4 is offline   Reply With Quote
Old 06-08-2008, 03:40 PM   #2
measure from the last piece you hang to the corner at
top== 10inch
middle=== 11inch
ottom== 10.5inch.
measure your paper across the top (width) 1/2inch more than your highest measurement. 11.5 inches. mark it & trim it from top to bottom or bottom to top.
hang your 11.5inches piece into the corner. butting & matching up to the last piece you hung.
it should go round the corner a little bit.
now you are left with a strip of wallpaper approx 9.5inches wide. hang this piece into the corner overlapping the other strip.. now plumb this piece for straightness. i always use a 3 foot spirit level. trim any overlap in the corner.
now you have a straight edge to work from to do your next wall.
i always use boarder adhesive to stick the edges in the corner.
hope i've managed to explain it so you can understand.
len
corni is offline   Reply With Quote
Old 06-13-2008, 03:34 PM   #3
i always paint my corners with matt emulsion. any mistakes with scissors show the white emulsion not a dark patch.
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 07:00 PM
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
