Wallpapering - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-31-2009, 11:27 AM   #1
Lightbulb
wallpapering
I have grasscloth that is on paneling. I want to put paintable wallpaper over it. What should I do to prepare the walls without taking off the grasscloth?
volleyball13 is offline   Reply With Quote
Old 08-02-2009, 04:30 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
PLEASE , remove the grass cloth first. You will be happier with the final results. Grass is one of the easiest papers to remove, here is a link. Also if you are looking to change colors, it is very easy to just paint the grass, it is done all the time. An oil based primer should be applied first or if it is really stuck, as in applied without priming first, you could probably use Gardz as your primer and avoid the oil.
http://www.wallpaperinstaller.com/wa...stripping.html
Old 08-06-2009, 05:42 PM   #3
thanks chrisn, i was also in search of this question
Last edited by AtlanticWBConst.; 08-08-2009 at 07:15 AM. Reason: SITES RULES VIOLATION: Furniture Advertising Links Removed from Post.
jhoncarry is offline   Reply With Quote
wallpapering round corners johnbrk4 Interior Decorating 2 06-13-2008 03:34 PM
