Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-10-2011, 12:39 AM   #1
wallpapered paneling in mobile home
how do paint over paneling with vinyl wallpaper in mobile homes
fannykstein is offline   Reply With Quote
Old 07-11-2011, 09:53 AM   #2
m1951mm's Avatar
From your description I am confused if the paneling has wallpaper applied to it or if the paneling itself is vinyl coated. Pretty much in either case you would need to scuff the surface (sand) and prime with an oil based primer before you apply regular latex paint. There are lots of threads you could search that explain how to paint over wallpaper or paneling.
Good Luck
m1951mm is offline   Reply With Quote
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 03:13 PM
running electric under mobile home brianbrianj Electrical 6 05-09-2010 04:49 PM
Dyrwall for Mobile Home Suncrest79 Building & Construction 3 03-04-2009 08:05 AM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 05:51 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 01:25 PM
