Wallpaper Over Fresh Joint Compound - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-24-2008, 04:47 PM   #1
wallpaper over fresh joint compound
Hi. I recently decided to make a number of 3inch diameter holes in my plaster wall in order to blow in some cellulose insulation. Next we will be wallpapering this wall. I have already used "plaster patch" plaster to fill the holes. And I am now using pre-mixed joint compound (in a tub) to smooth over the repairs. However, I am worried about putting the wallpaper over this stuff. Should I do anything before putting up the wallpaper (sizing or priming for example)? Thanks.
Joe71 is offline   Reply With Quote
Old 02-24-2008, 04:59 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Prime it first.
- Build Well -
Old 02-24-2008, 05:04 PM   #3
some wall papers show wall coloration thru the paper, its often a good idea to prime or paint with the color of the wall so you don't have that problem. check your wallpaper manufacturer's instructions to see if they recommend sizing.
nacko is offline   Reply With Quote
Old 02-25-2008, 08:20 AM   #4
It's been years since I wallpapered so I'll ask this question for my own general knowledge purposes but doesn't a plaster wall have to be "sized" - even after it's primed - so that the wallpaper paste (adhesive) has a better surface to bond onto?
End Grain is offline   Reply With Quote
Old 02-25-2008, 01:12 PM   #5
The OP said that they coated over the repaired areas with drywall compound.
- Build Well -
Old 02-25-2008, 03:37 PM   #6
She'sapainter
Use primer, Some paints counteracts the glue, Read the specs on your adhesive.
PS
if I'm not mistaken seizing is what you do to the wall paper not the wall
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-25-2008, 06:43 PM   #7
Rewards Points: 528
The primer instructions should give the cure times in additon to the surface dry times. Use the cure times to determine when you can install wallpaper.
rjordan392 is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
premix joint compound vs setting type ITE Drywall & Plaster 32 03-12-2014 04:04 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 07:11 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 06:19 AM
