-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Using same tile for bathroom and kitchen too Matchy-Matchy? (http://www.diychatroom.com/f50/using-same-tile-bathroom-kitchen-too-matchy-matchy-65807/)
Jeanene 03-02-2010 03:42 PM
So I posted this in the wrong section in "Flooring" So I moved my question here.
Hello I'm doing a downstairs bathroom/laundry room remodel and replacing the floors in the kitchen. My bathroom and laundry room together are roughly 55 square feet and the kitchen is around 88 square feet. Originally I was thinking of doing 18x18in tiles in both rooms but I taped off what 18's would look like in the bathroom and I wasn't sure if the big tiles would make the room look smaller, What do you think, will it make the room look smaller?
http://i73.photobucket.com/albums/i2...Picture003.jpg
I taped off 18" in the kitchen too:
http://i73.photobucket.com/albums/i2...cture002-1.jpg
Here is a 12" and a 18" for comparison. (I'm not using the bottom tile because it doesn't have the finish I like I just picked it up for size reference.)
http://i73.photobucket.com/albums/i2...Picture001.jpg
So I was thinking of doing the 18" tile in the kitchen and 12" in the bathroom of the same tile(the top one). Is this too matchy-matchy to use the same tile in the two rooms? Another thing is, my mom thinks that I should do a 12" tile in both rooms just to make it look more consistent, but im afraid the 12" will look too busy in the kitchen.
So I guess im looking for second opinions:
-18" for both rooms,
-13" for both rooms,
-18" for kitchen & 13" for bathroom using same tiles,
-or 18" for kitchen & 13" for bathroom using different tiles?
We are ultimately looking to rent/sell the condo so I need to know what people's opinions are on this. Thank you so much for reading! :)
bobtheblindguy 03-02-2010 07:52 PM
I would definitely go with a different color tile in the bathroom. Same tiles in both rooms will be noticed. I would also switch to a 6x6 in the bath.
Mop in Hand 03-02-2010 11:39 PM
I disagree, same tile thoughout. 12" is what I would use. My reason for the same tile is the same reason wall to wall carpet is used from room to room. It flows.
Scuba_Dave 03-03-2010 07:03 AM
I would do both in 12" tiles
I wish I had used the same tiles in my bath & hallways
ConstantChange 03-06-2010 12:49 AM
I would definitely use the same tile in both places.
From your pictures, 18" looks good to me, but you'd be cutting almost every tile in the small bathroom.
I would see if a tile store will let you borrow a few 18" and 12" tiles and try it out. See which layout looks best to you.
Scuba_Dave 03-06-2010 08:48 AM
There is one "advantage" to using different tile
If you need/decide to replace tile you don't have to do it all
Frostbite 03-08-2010 01:26 PM
I like the idea of having smaller tiles in the bathroom since it is smaller and you get closer to the floor (sitting vs. standing) I also think that you should use a different and more textured tile in the bathroom since you are more likely to to bare foot in the bathroom.
Blondesense 03-08-2010 07:09 PM
I would use the same. Better flow.
I like the look of the 18 inch, but if I were doing it myself I would go with a 12 or 13 inch because they are a bit more forgiving to install. If you use a matching grout I don't think it will make a huge visual difference.
(And I know you didn't ask this, but it appears you are going from vinyl to a tile so be sure your subfloor is adequate.)
bobtheblindguy 03-09-2010 08:09 PM
If the bathroom and kitchen floor flowed together then the same tile would be fine. But it looks like the bath is on a different level the the kitchen. So a different smaller tile would be better . Unless this is a rental.
Ivy 03-25-2010 12:19 AM
I'm using the same tile in the kitchen, powder room and front entry (all on the same level). The upstairs main bath will get a totally different look.
redrover 03-29-2010 12:38 AM
my take on tile
My home is 1 complete half sq ft main floor the same tile and with relatively open floor plan aesthetically flows. Entry R into Kitchen flowing into Dining and L down hall, passing main bath and laundry with same tile with Living and den same color(ish) carpet. Master bath has no door, same white carpet becomes same tile passing closets into bath. I didn't do it but think it was a great idea using the same tile. Means purchasing and storing less overage for oops's and repair, very smart. But on the other hand…
From the photos your spaces appear small and unless chosen tile very dark like the hallway pictured, are abrupt transitions and room delineations. Two completely separate rooms/spaces with the same tile I would notice, and seem matchy matchy. Chosen for convenience, perhaps randomly and in fact imply lack of inspiration. I think aesthetics better served by going with separation of space, each flooring unique with unique room atmosphere.
The bath on a diagonal is creating a great deal of work for yourself with the effort lost (and perhaps too busy) in that teensy space. Great idea with visual tile samples and tape, gotta remember that. To me the smaller tile is clearly more proportionate for the space. (I wonder what mosaic would look like?)
I am a big fan of divergence however and perhaps the kitchen on diagonal would open it more visually (it appears quite cramped) and worth the extra work to cut.
Just my thoughts, I do tend to be conversely opinionated. J
