Using Fabric/cloth On Basement Ceiling - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-22-2013, 11:31 PM   #1
Rewards Points: 422
Using fabric/cloth on basement ceiling
Has anyone used some sort of fabric/cloth on their basement ceiling? If so, what did you use and how did you hang it? My daughter is considering doing this to cover the ceiling joists, etc. of her basement ceiling. Thanks.
Jim McC is offline   Reply With Quote
Old 08-23-2013, 08:06 AM   #2
Too Short? Cut it Again!
Sagging could be an issue but it is worth a shot. Stretch it as you go. I would use some sort of canvas, sailcloth or parachute fabric and furring strips or lath to hold it to joists. Use tacks or long staples to go through everything. Paint the lathe first so it blends. Fabric too thin would be prone to tearing. It may be hard to keep clean in a basement.
Or if defining a space you could paint the underside of the floors and joists, twist fabric from several directions and gather it at the middle and not try to cover everything.
Do be mindful of fire hazards and buy fabric treated or treat with a fire retardant if putting any sort of light source behind the fabric. Keep a rated fire extinguisher and active smoke alarm in the basement anyhow.
I have seen some fun fabric ceiling treatments with firefly LED lights hidden above the fabric. The approach is used in the theater set world so could work for you.
Old 08-23-2013, 10:48 AM   #3
K&B Designer
Live_Oak's Avatar
If the basement is habitable, that won't pass fire code without a layer of drywall underneath. With the drywall up, you can adhere it with liquid starch, just like you can on a wall. It's just kinda shocking to see that idea come around again full circle. In the 70's fabric or carpet on the ceiling was all the rage. Like The King's basement game room.
Live_Oak is offline   Reply With Quote
Old 08-23-2013, 02:06 PM   #4
Rewards Points: 422
Thanks guys. Painting the ceiling joists, etc. is the other choice. The problem is the walls are already finished and floor is carpeted. So if we used fire retardant fabric, we would still need to put up drywall first to meet code?
Old 08-23-2013, 09:56 PM   #5
K&B Designer
Live_Oak's Avatar
Your dilemma is why suspended ceilings are so popular. They provide the necessary fire resistant material and yet you are able to easily move them aside for access to the utilities. It's not that difficult a job to do either. Perhaps you should consider checking out Armstrong's ceiling tile collection? There are other manufacturers as well but Armstrong is readily available at most box stores for DIYers.
Old 08-24-2013, 09:21 AM   #6
Rewards Points: 220
yeah, i did, years ago.
basic black fabric and tacs. piece of cake and it looked nice for what it was.
Fix'n it is offline   Reply With Quote
Basement ceiling question aggst1 Remodeling 9 05-07-2013 04:23 PM
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 06:17 PM
Basement Ceiling OhioDon Building & Construction 9 08-09-2010 02:33 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
