Updating 1970's Plain Closet Bi-fold Doors - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-17-2013, 12:11 PM   #1
updating 1970's plain closet bi-fold doors
My house was built in 1977 and I've lived here for 23 years. All of the closet bi-fold doors are cheap and plain. I'm going to paint them because they are part of the 1970s oak color (not real oak!) that was everywhere back then. I can't afford to replace them with raised panel doors but I'm thinking of trimming them out to give the appearance of a nicer door. Anyone ever done this? I'm attaching a pic of the doors as they look now.
Kansas Girl is offline   Reply With Quote
Old 03-17-2013, 12:29 PM   #2
Rewards Points: 14,306
Lots of differant things you could do to the doors and that trim.
Looks like someone used base board instead of casing for the trim.
Something as simple as adding back band moulding to the outside edges of the trim would make it look far better.
Does not need to be hardwood, pine would be fine.
http://www.fatandys.com/moldings/Backbands/index.htm
The doors could be covered with beadboard and be made to look like recess panels by adding thin strips of 3" wide wood.
Or bordered with something like base cap moulding.
Old 03-17-2013, 12:41 PM   #3
Every time I start a project in this house I am horrified at what the builder did 35 years ago.
Old 03-17-2013, 12:47 PM   #4
Are those doors 10' tall or are those knobs placed for a little person?
Nothing wrong with using base as a trim, just looks to me like someone was using what was laying around instead of using casing.
Old 03-17-2013, 01:18 PM   #5
I hate cheap little knobs, Joe. Notice that one is already missing. I'll put nice handles on those doors when I'm done revamping them.
Old 03-17-2013, 01:29 PM   #6
My bifold doors are 10 years older than yours but they're slightly recessed. If you think recessed would look better, you could remove the trim and move the track and add new trim that's inset like mine. But I have no opinion on whether it's a good idea. I think painting would be an improvement though, if its not real wood.
Dorado is offline   Reply With Quote
Old 03-30-2013, 09:06 PM   #7
I started on my closet doors facelift today. 2 doors trimmed and primer on.
Old 03-30-2013, 10:00 PM   #8
I hoped you checked whether they'll open wide enough now.
Old 03-30-2013, 10:16 PM   #9
Well, duh. Of course I did!
Old 03-31-2013, 04:33 AM   #10
Are you trying to paint these with a brush?
It would be a whole lot easyer if the door was removed and was laying down.
Using a 6" foam roller would give you a far flater finish.
You did clean, sand and clean them first, right?
Using a bonding primer?
I would have primed and painted the door and trim before the trim was install.
That way your just doing touch up and not having to cut in around the trim.
Old 03-31-2013, 11:23 AM   #11
Don't forget the edges that show only when the doors are opened. You may have to sand those down first so the paint doesn't make them stick together or prevent them from closing. And leave them opened while they dry.
Old 03-31-2013, 12:18 PM   #12
Already prepped and primed and doors are open while it dries.
Old 04-01-2013, 11:18 AM   #13
Looks like you're going to need a few more coats? If you can, post an update when you're done. Looks like you're going from a retro look to a neutral one.
Metro is offline   Reply With Quote
Old 04-01-2013, 03:16 PM   #14
Going for cottagey-mission look. That's just the primer so not covering all that great. Here's some pics of the rest of that bedroom and the attached bath.
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Updating plain doors - Need Help sebbiemasc Carpentry 8 02-13-2009 02:57 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 02:38 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
Mirrored closet doors VVAVALE Painting 2 08-19-2006 06:34 PM
