Trim? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-10-2009, 10:12 PM   #1
Trim?
I have just put on a 3 bedroom, Entry way,sitting room and redooing the old part( a cabin with alot of knotty pine (wall), I dry walled the celing to our house(the old part) The new part is all dry walled. I am getting ready to trim the house. I have unpainted Jeld Win windows on the interior, white vinyl clad ouside. If I run White trim should I paint the windows? I am considering Trimming the House in Raw Cherry(just a clear,no stain). Is that going to look funny with the wood windows since the windows are not cherry? any advice would be appreciated.
Long term plan all Knotty pine will be removed and kitchen will be Raw Cherry cabinets.
drzjoint is offline   Reply With Quote
Old 03-11-2009, 07:21 AM   #2
Yes you should paint the windows with the trims or it will give an untidy look.
Dana
http://www.ninaathome.com/
Dana11 is offline   Reply With Quote
Old 03-11-2009, 09:05 AM   #3
Remodeling Contractor
I would stain the windows and the window trim to match the cherry color. Cherry color can vary extensively. You will need to first use a pre-conditioner so the stain is not blotchy. Then mix stain colors to get the color to match the other natural stain. The grain will not be the same but you can match the color.
Old 03-11-2009, 12:27 PM   #4
So I can stain the windows to match the raw natural cherry in color?
Will it look goofy after a few years when the cherry startes to darken, or will it still blend ok?
Old 03-11-2009, 01:35 PM   #5
Both will darken over time, but the natural cherry if in direct sunlight will darken more. But this means that windows not in direct sunlight will also look different. Maintenance... stain again ,... it's all part of home ownership.
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 04:17 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
