Tempered Or Regular Glass For Tables? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-13-2011, 08:22 PM   #1
Rewards Points: 33
Tempered or regular glass for tables?
I have a coffee table that needs glass. I called a few glass shops and was told I could use regular glass over tempered. But the guy I brought the tables from said to use tempered glass because it was stronger. I need more knowledgeable answers on what is the proper glass to use for these living room tables.
Sliding Man is offline   Reply With Quote
Old 05-13-2011, 08:27 PM   #2
Rewards Points: 558
Use tempered glass it is regularly used in applications in which standard glass could pose a potential danger. Tempered glass is four to five times stronger than standard glass and does not break into sharp shards when it fails. Tempered glass is manufactured through a process of extreme heating and rapid cooling, making it harder than normal glass. Use it and be safe.
epson is offline   Reply With Quote
Old 05-13-2011, 08:58 PM   #3
Too Short? Cut it Again!
Agreed. But how thick is the glass? Tempered glass may be overkill unless you have kids or a temper prone to breaking it. It is safer and easier to clean up if it breaks for sure. It will no cost you that much more.
What did you mean by using regular glass over tempered? I would not layer glass for a table top just for aesthetic reasons to start.
Old 05-13-2011, 09:19 PM   #4
Rewards Points: 558
Ok two sides to this coin.
1) If the glass you’re using is ½’’ or ¾’’ thick than the top does not need to be tempered.
2) If you’re using ¼’’ or 3/8’’ thick then the glass has to be tempered.
So to answer your question, the standard table top is usually 3/8’’ thick and it should be tempered
The Following User Says Thank You to epson For This Useful Post:
Sliding Man (05-15-2011)
Old 05-13-2011, 09:38 PM   #5
Learning by Doing
Leah Frances's Avatar
Didn't someone on the forum make a big glass picnic table? Was it DM or SD? I always get those two jokers mixed up..... Just kidding. there's a thread about glass tables around here somewhere.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-15-2011, 06:16 PM   #6
Rewards Points: 33
Sorry for the late response. Neither one explained what the regular glass was exactly. The thickness would be 3/8" thick measured from the inner space to the surface of the frame.
Tempered Glass requirement Larry Inmon Building & Construction 1 05-06-2011 02:22 PM
type of glass (tempered, laminated, etc.) myrtal Building & Construction 3 08-14-2010 09:03 AM
Tempered glass needed or not? DangerMouse Building & Construction 5 04-29-2010 07:34 AM
When is tempered glass required? vsheetz Building & Construction 4 01-17-2009 10:53 PM
Replacing regular glass with low-e in vinyl frame. Doug Crf Building & Construction 1 10-02-2006 07:31 PM
