Suggestions Please! I Have An Exposed Basement Beam To Do Something With (see Pic) - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-02-2012, 09:03 PM   #1
Suggestions please! I have an exposed basement beam to do something with (see pic)
The attached picture is my problem. I'm racking my brain trying to figure out how to cover this ugly support beam and support columns and make it fit with surroundings. I'm not partial to just painting. Please, any suggestions with pics would be much appreciated!
BPetk7 is offline   Reply With Quote
Old 10-02-2012, 09:57 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
clad it drywall or mdf
woodworkbykirk is online now   Reply With Quote
Old 10-02-2012, 10:04 PM   #3
DIY staff
Rewards Points: 7,174
What is that? Is it structural or is it decorative? If structural--it doesn't look right---How is it held up?
user1007 (10-08-2012)
Old 10-03-2012, 08:59 AM   #4
Rewards Points: 13,300
Is that just a single 2X being used as the beam
That had to be some DIY's attempt to fix a sagging floor.
A tripled up set of 2X's and at least doubled (tripled would be better) up jacks on each end would have alowed enough support and gotten rid of that post in the middle.
There also needed to be a footing under those end supposts, not just sitting on a 4" thick slab.
Old 10-07-2012, 11:13 AM   #5
funfool's Avatar
Rewards Points: 534
Agreed, looks like it is just for decoration, certainly is not doing anything structural.
Maybe better pics of the ends would help.
I would put better supports under it before covering it up as suggested above.
is many ways to cover it, hard to suggest covering / hiding a problem.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
Old 10-07-2012, 11:33 AM   #6
Make it look like a totem pole ?
creeper is offline   Reply With Quote
Old 10-08-2012, 02:43 PM   #7
Too Short? Cut it Again!
I noticed too that nothing seems to be holding it up? I see no hanger on the far end (but perhaps that 2x4 is nothced) and their is a matching one on the masonry wall. And it is a beam that cannot be balancing on that 2x4. Lucky that thing has not come down on someone's head. Least of your worries should be about how to decorate or blend it in!
Old 10-11-2012, 09:43 AM   #8
DIY-er
Once you fix the structural problems as suggested by other posters, you could run a dropped ceiling from the wall to the beam and add recessed lighting. It will make the area where the couch is appear to be more cozy.
KevinPh is offline   Reply With Quote
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Basement beam concern Rife Building & Construction 1 07-11-2010 01:16 PM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 12:41 PM
Putting support beam in basement billybarty Building & Construction 8 04-10-2008 04:14 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 06:03 PM
