Standard Mirror Height In Bathroom - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-26-2011, 10:13 PM   #1
Newbie Bill
Rewards Points: 522
standard mirror height in bathroom
Hey Everyone,
Is there a standard height at which a mirror should be hung in a small 1/2 bath?
We have an oval mirror 27" high and about 20" wide. Mirror photo and wall photo attached.
The top of the vanity back-splash is 36" high and bottom of light fixture is 79" high. So I have a space about 43" in which to install the mirror. Should it be centered in that 43" space? But that would put the mid point of the mirror at about 58" which is about chest height and wouldn't that look weird? The mirror tilts so it'll be functional no matter what level. I'm just thinking from an esthetic perspective, should I mount it higher and not worry about it being centered?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-26-2011, 10:20 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm thinking there is a code (somewhere) that says the bottom of the mirror should be 40" above the floor.
You put that mirror where you think it looks best.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
drtbk4ever (05-27-2011)
Old 05-26-2011, 10:25 PM   #3
yummy mummy's Avatar
Rewards Points: 1,016
I would like it centered, from on top of the backspash little ledge to the bottom of the light fixture.
Nice bathroom btw.
yummy mummy is offline   Reply With Quote
The Following User Says Thank You to yummy mummy For This Useful Post:
Old 05-27-2011, 01:59 PM   #4
Newbie Bill
Rewards Points: 522
Thanks you two. I just wasn't 100% sure so thought I would ask.
YM, thanks for the comment. We can only take credit for the materials, not the installation. Although the light was a DIY install.
I am going to install 5/8" black/blue glass black marble mosaic tiles on the wall before I install the mirror. It should be stunning although the tile will make the room seem a bit smaller.
I'll post another photo when done.
Thanks.
Bill
Old 05-31-2011, 06:18 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Raise and lower the mirror until he or she can see most or all of his or her body, including shoes. When the proper amount of the body can be seen in the mirror, measure the distance from the floor to the bottom of the mirror. This will be the distance up from the floor that the bottom of the mirror should be mounted.
Is that how you do that? I would have never guessed that!
XXX
Old 05-31-2011, 06:25 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
4.19.6* Mirrors. Mirrors shall be mounted with the bottom edge of the reflecting surface no higher than 40 in (1015 mm) above the finish floor (see image above).
Well here ya go. I knew I wasn't dreaming about the 40" bottom of a mirror height. It is the ADA Standard I was thinking of. So....In that case THERE IS A STANDARD AFTERALL.
Imagine that...Ole Bud was right again. Don't you guys just hate it when that happens?
XXX
drtbk4ever (05-31-2011)
Old 06-06-2011, 10:31 AM   #7
I just measured, and we did 40 inches from the bottom of the sconce. I'm sure there are many right answers, good luck with this one!
manandvan is offline   Reply With Quote
Old 06-06-2011, 01:37 PM   #8
Old School
Willie T's Avatar
It's happened before?
Willie T
Old 06-06-2011, 01:44 PM   #9
Old School
Willie T's Avatar
I install that particular mirror all the time. (I hate the mounting of it, BTW)
What I have found to look best is to measure the distance from the bottom of the lights to the top of the back-splash.
Subtract the mirror height.
Divide the remainder by three.
Two thirds of that left over measurement is the space under the bottom edge of the mirror and one third is the space above the top edge.
Of course this assumes that there is nothing like the faucet in the way at the bottom... but usually that two thirds helps you clear most faucets.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
drtbk4ever (06-06-2011)
Old 06-06-2011, 06:50 PM   #10
Newbie Bill
Rewards Points: 522
Good info Willie,
We got the wall tiled this weekend. I will grab the mirror and have the wife consider the spacing you mention.
Bill
Old 06-10-2011, 09:46 AM   #11
thats always hard here, wife is 5' i'm 6'3". makes new window height arguments fun
The older I get the better I was
Old 06-10-2011, 06:38 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow but it's probably easier for you to hide your popcorn supply.
XXX
Old 06-10-2011, 07:47 PM   #13
Missouri Bound's Avatar
The top of the mirror should be 12 inches above eye level. Average that measurement for two or more people.
Old 06-12-2011, 09:00 PM   #14
design schools' standard
The standard taught from design schools is usually the center of pictures/picture groupings/mirrors placed at 5 1/2 feet from the ground. This will place it at the average person's height so that most people, at all heights, will be able to see in the mirror. However, I would try to incorporate a happy medium for the bottom being 40 inches from the ground to the center being at 5 1/2 feet from the ground to allow for a person in a wheel chair to see just fine.
agsizemore is offline   Reply With Quote
Old 07-09-2011, 12:08 PM   #15
Newbie Bill
Rewards Points: 522
Here is the finished product. Mirror could have been bigger, but it still looks pretty good in my opinion.
Bill
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 11:44 AM
