Sliding Glass Closet Doors - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-26-2010, 10:42 PM   #1
Hi everone. We just purchased a coop apartment. There is a large closet in the livingroom. The closet has three sliding glass doors with gold trim. Not only are they unsightly, but I feel they are dangerous as we have an active toddler. We would like to have them changed to wooden doors, but are worried this might make the room look smaller. It is a living/dining combo roughly around 320 square feet. What do you think? Also, any suggestions on who to contact if we decide to change them (a contractor)? Thanks so much.
newhome2 is offline   Reply With Quote
Old 10-27-2010, 01:40 AM   #2
jlhaslip's Avatar
Rewards Points: 390
Most closet mirrored doors should be tempered glass or safety (laminated) glass and should present little problems for toddlers.
The gold frame might be able to be swapped or painted.
Check with a local hardware store. They might know of a 'handyman' or carpenter available to swap them out or otherwise handle that issue.
As for the size issue, hard for us to say without a picture or drawing.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-27-2010, 12:39 PM   #3
Thanks for your quick reply. I was so tired when writing that I forgot to mention that they were mirrored doors which make the room look larger. Good advice about painting or changing just the trim! We never thought of that.
Old 10-27-2010, 01:13 PM   #4
concretemasonry's Avatar
Rewards Points: 2,566
Replacing the mirrors with wood doors will definitely make the space smaller and darker.
Dick
concretemasonry is online now   Reply With Quote
Old 10-31-2010, 11:57 AM   #5
Changing trim colors will most definitely be an improvement.
Oops! is offline   Reply With Quote
Old 11-01-2010, 11:33 AM   #6
harleyman's Avatar
Do you have a picture you could upload?
harleyman is offline   Reply With Quote
Old 11-02-2010, 01:42 PM   #7
Hello newhome2 and congratulations on the new apartment!
As long as the mirrors are in good condition, it may be cost-effective and easier to keep them in place. Plus, you can keep an eye on your busy toddler – like you have eyes in the back of your head! Wooden doors will make the room seem smaller and cozier.
The gold trim does sound dated and probably does not match other hardware found in the living room (ceiling fan, lighting, cabinet and furniture door pulls and knobs, etc.). There are some no and low VOC paints on the market that can change the trim and cause little odor and discomfort – especially with your little DIYer running around! You could coordinate the look with your furniture or even create a “faux finish” to look like wood on the trim. Just be sure to prime the trim before painting or use a paint + primer paint.
If the mirrors seem to be “too much,” consider using a window film to ‘tone them down” a bit. There are some that have a frosted look and even a stained glass feel.
Best wishes on this project – and be sure to send before and after pictures! We’d love to see how things turned out.
Designing Woman
DesigningWoman is offline   Reply With Quote
Sliding closet doors and baseboard olli Carpentry 1 07-29-2010 07:47 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
How do I remove sliding glass doors? upinsmoke Building & Construction 4 06-05-2010 05:41 AM
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 11:09 AM
8' Glass Sliding Doors dankreboot General DIY Discussions 6 07-10-2008 09:11 AM
