Sheer Panels - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-06-2011, 09:33 AM   #1
Sheer Panels
Hi Experts,
I like sheer panels a lot and I have few in mind. The only problem is that they'll be see through at night with the lights on inside. Is there a workaround for this problem? I dont want to put blinds at all. Any other option please...
ThankYou
Waal is offline   Reply With Quote
Old 09-06-2011, 08:45 PM   #2
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Use the sheers on a separate rod behind heavier drapes, keep the drapes open in the day (so you can see the sheers) and closed at night for privacy.
ghostlyvision is offline   Reply With Quote
The Following User Says Thank You to ghostlyvision For This Useful Post:
klmeenan (09-06-2011)
Old 09-07-2011, 04:45 AM   #3
m1951mm's Avatar
The fullness of the sheer will make the difference in what can be seen from the outside at night. If you put more than one panel on the rod it will help obsecure the view. If you are using pinch pleated sheers make sure that the fullness (fullness is the amount of fabric that goes into the width of the panel, i.e. for most fabrics you use 2.5 times the width of the window for the width of your treatment, for sheer 3 times the width of the window is the amount you want for privacy) is 3 times the width of your window.
Are you purchasing premade sheers?? If so what is the style? What is the width of each panel? What is the width of your window"s"? Are you having the sheers custom made? Will the sheers be closed all the time or are you using a traverse rod making it so you can open and close your sheers? Once these questions are answered I may be able to help you further.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Neutral path between two main panels EMiller Electrical 13 03-17-2014 08:48 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 09:43 AM
Metal roof over Zip panels Arky217 Building & Construction 1 08-14-2011 11:37 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
