Securing A Bookshelf - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-05-2011, 12:48 PM   #1
securing a bookshelf
Is there a way to safely secure a bookshelf to the wall by only affecting the wall - no screws/nails in the furniture? For example, could we use cable ties?
Beth Lloyd is offline   Reply With Quote
Old 07-05-2011, 01:53 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I suppose it would depend on the piece of furniture. Pics might help with this question.
FWIW, with shorter bookcases I'll usually just use shims under the front to "lean" them back against the wall. But with a taller bookcase, you do want to secure it.
Old 07-05-2011, 03:05 PM   #3
m1951mm's Avatar
Your thought about using cable ties is interesting, but I wonder how you would attach the ties to the furniture without screws. I do agree that shims under the front side will stablize a bookshelf for the most part. If your bookshelf is open back you could attach a cleat to the wall just under the top for a more stable usage. A cleat could be just a 1 x 2 piece of wood cut to the inside measurement of the top opening and attached to the wall. The shelf would ride on top of the cleat and the lenght would keep the shelf from moving side to side.
m1951mm is offline   Reply With Quote
Old 07-06-2011, 07:45 AM   #4
Too Short? Cut it Again!
You can use some sort of safety cleat, like those used to mount appliances and tool cabinets. I don't see how you can avoid fastening it too at least the backside of the furniture somehow.
I guess you could use some sort of strap or pallet banding system that would run through a bracket or two anchored in the wall in back of the furniture but won't the strapping running around the bookcase look unsightly?
http://www.uline.com/Cls_09/Strappin...FZQ5KwodHAPdag
Why the resistance to anchoring the bookcases? You can set the fasteners under the surface and plug holes on top so nobody ever sees them.
Old 07-18-2011, 01:06 PM   #5
You need to attach the brace to the bookshelf. The only ways to do that are by screwing/nailing something to it, gluing something to it, or tieng something to it.
I think people get paranoid about putting (small) holes in their furniture. Unless its a very nice piece, I would say a small hole is worth the security and stability it will provide.
kuj0317 is offline   Reply With Quote
Old 10-03-2011, 07:55 PM   #6
Duct tape???
toilet is offline   Reply With Quote
Securing CSST gas line NowItsShowtime Plumbing 10 04-29-2011 10:15 AM
Securing NM in walls gm8075 Electrical 1 03-21-2011 12:43 AM
How to secure a bookshelf without using screws or nails? samdi General DIY Discussions 6 09-14-2010 02:12 PM
securing cables and boxes...code? drgkjd Electrical 2 05-30-2010 09:25 PM
Hanging a bookshelf on the wall Cobb General DIY Discussions 5 12-10-2008 09:10 AM
