Restoring Bathroom Wall And Ceiling To Put My House Up For Sale - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-05-2009, 04:29 PM   #1
Restoring bathroom wall and ceiling to put my house up for sale
Hi forumers,
A few years ago, my dad made a shoddy patchwork on my bathroom and thought that was the solution for mildew buildup. It is laminate glued and nailed onto the ceiling and walls. The wall and ceiling itself has dents in several places, but not very deep. This is simply not a great way to sell my house. Now I want to restore it, so I can sell it at a higher price. What is an affordable solution?
Any help is appreciated. Thanks
sturmnacht is offline   Reply With Quote
Old 08-05-2009, 06:49 PM   #2
the Musigician
DangerMouse's Avatar
wow...
rip it all down, start the whole bathroom over... you'll probably need to open that wall to install the fan correctly... that wiring is SO illegal!!!
DM
Old 08-05-2009, 06:52 PM   #3
Disconnect that wiring, light & fan right away
Dangerous & illegal
Your best bet is to rip it all down & start over from bare studs
You might get away with ripping it off & putting on a textured finish
Those wires need to be run INSIDE the wall without exception
The fan needs to be installed in the ceiling & vented corerectly
NOT thru the shower
Use of paint with proper mold & mildew prevent/additives will stop mold from growing
That & properly installed & sized ventilation fan
Old 08-05-2009, 07:04 PM   #4
the Musigician
yup, any pre-sale inspections will surely fail, so you really have no choice but to do it to code.
DM
Old 08-05-2009, 07:05 PM   #5
I've got to echo the previous comments.
Any smart buyer is going to see this as a huge red flag and is not going to touch your house with a 10 foot pole; unless of course they factor in a huge discount.
Either way is not the outcome you want.
You want to sell your house for the best $$. This means that the smart, and financially correct decision, is for you to 'gut it' and make it right.
Put another way... spend $5,000 now or spend $20,000 on a lower sale price.
derf36 is offline   Reply With Quote
Old 08-05-2009, 07:20 PM   #6
the Musigician
$5,000??? i have to assume you mean if he hires a contractor. lol
he can DIY that for anywhere between $200 and $500 if he's a wise shopper and handy.
all the walls may not need to be gutted too, just the affected areas. it also depends on how (easily???) that lino is to remove.
but that wiring certainly will need to be brought up to code. that's dangerous, for sure.
DM
Old 08-05-2009, 08:01 PM   #7
Yeah, I didn't spend $5k gutting & redoing my last kitchen
If those glue/nail tiles are in the shower area I'd take 'em down & tile in there
Old 08-05-2009, 09:11 PM   #8
DM
ok ok you got me with the $5k, maybe a bit on the high side. You are right. You, I, and maybe the OP, would not have to hire a pro and spend that kind of money.
I am guilty of reading between the lines. The photo shows a bathroom that needs some serious care and attention. The OP's father worked on it last so I am assuming the OP is not that handy? I could be wrong and he/she is ready to take on this challenge and if so I commend them.
My $5k comment was simply to make a point. Maybe an assumption but not correcting the bathroom the right way now could cost the homeowner some serious $$ during the sale.
Old 08-05-2009, 09:22 PM   #9
True, if needed hire this out
But this also depends upon the condition of the rest of the house
And it depebds upon the neighborhood, size of house, # of bathrooms, average selling price in the area
A fancy bathroom with a so-so house/neighborhood will not increase the value that much, if at all
Old 08-05-2009, 09:27 PM   #10
DM
I realize about the wiring. I guess I'll just take the fan out and sell. All that wiring is only because of the ventilation fan; lighting will not be affected.
I tore some of the lino out earlier today. It did not look too bad. The old paint under it has to be scraped out too. Use of compound to fill the holes, then wipe the walls clean, then repaint.
Old 08-05-2009, 10:05 PM   #11
The neighborhood is sub-par, and it's a bungalow with one bathroom. The house itself is over 60 years old. I can sure bet the houses next to mine have worse interior and exterior.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
