once the old top is removed check and make sure that the existing cabinets are sound and level across there tops. install cleats behind dishwasher against wall. check on the size of your floor joists also, you don't want any deflection of the floor, I have seen a granite top crack in mid span by sink because of the floor joist being under sized with 2x6's. you should be fine, but it should be up to the granite top fabricator to determine the structural support of the top, being there going to warranty it. BOB
