Privacy Window Treatment For LOWER 1/2 Of Window - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-21-2009, 08:56 PM   #1
privacy window treatment for LOWER 1/2 of window
I need do some sort of window treatment for the lower half of basic double hung windows. I really do not like the look of shutters. any suggestions?
thanks for the help,
Scott
scrappyanddigge is offline   Reply With Quote
Old 11-21-2009, 09:01 PM   #2
You might try cafe curtains
I added a curtain rod across the middle of the windows and made curtains which hang from small drapery rings. Make sure your curtains are not too short and hang just below the windowsill.
gingerbo is offline   Reply With Quote
Old 11-21-2009, 09:21 PM   #3
A Top Down Bottom Up Roman Shade is a nice solution.
privacy window treatment for LOWER 1/2 of window-top-20down-20bottom-20up-20roman-20shades-20by-20comfortex-2010.jpg
roxksears is offline   Reply With Quote
Old 11-22-2009, 01:10 PM   #4
Rewards Points: 150
You could also use a couple of tension curtain rods, one as high on the window as you want, and one at the bottom. Make or buy some panels and gather the panels at the top and the bottom. This admits light but also provides privacy.
shapeshifter is offline   Reply With Quote
Old 11-22-2009, 04:55 PM   #5
ArmchairDIY's Avatar
if privacy is a concern you can also apply a frosted looking window film.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 11-23-2009, 06:39 AM   #6
makes magic with fabric
Rewards Points: 14
Lower half privacy window
Nothing beats the top down/bottom up shades ! You control how much or how little light exposure. Worth the investment!!
moondancer is offline   Reply With Quote
Old 11-23-2009, 03:49 PM   #7
I got some "fanfold" off the shelf window shades at Lowes or similar. They're some kind of paper like material. Maybe $10.
Trim to fit.
They come with double sticky tape to hang them from the top of the window. I put them on the bottom. Then put an eye in the top and tie the pull cord. They work perfect. Adjust them up however far you like, blocking the view through the bottom, but leaving the top open. You can lower them when you want.
Only drawback is you loose the window sill, if you like to put things on it.
pyper is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 09:09 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
