-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Privacy window film (http://www.diychatroom.com/f50/privacy-window-film-13921/)
cactusrose1949 11-29-2007 11:35 AM
Privacy window film
We recently added a second cat to our home, and she does not tolerate the other cat. We don't want to get rid of either cat, so we found a way to permanetly separate them. This has worked well, except tfor he sliding glass door in the living room. I was thinking about a privacy window film for the lower half of the glass door, which would be decorative, and still prevent the one cat from seeing the other.
Before I go this route, I was wondering if anyone had another idea of how to block their view...maybe something cheaper or simplier. :confused1:
handy man88 11-29-2007 12:55 PM
Before I go this route, I was wondering if anyone had another idea.:confused1:
Even if the cats can't see each other, I'm sure they can sense or smell each other. Cat senses are way beyond humans.
cactusrose1949 11-29-2007 01:21 PM
Thanks for you reply.
Like you say, they are aware each other is there, but as long as they don't see each other, there is no problem. I only want to prevent them from seeing each other while one is in the porch and the other in the living room.
Concordseeker 11-29-2007 04:01 PM
Try the vinyl window films from a big box. They aren't permanent, are pretty cheap and come in lots of styles. After a looooonnngggg time the cats might just tolerate each other :)
cactusrose1949 11-29-2007 05:23 PM
Thanks a lot....I'll check it out
kjwoodworking 12-02-2007 03:28 PM
Hi, cactusrose1949
You can get window film that looks like a mirror. When installed ,the side with the most light.....outside during the day and then inside at night will be the side that has the mirror reflection. I have used this type in the past..for a different reason than yours but it worked well.
