Pillow Sham Inserts - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-26-2013, 12:26 PM   #1
Pillow Sham Inserts
I bought a new bedding set that has a bunch of different pillow shams. I can't get them to not look 'sloppy'. I even arranged them on the bed the same way they showed in the catalog. The shams seem droopy. I was thinking I need denser pillow inserts so they hold their shape better. I've tried a few different pillows but none are dense enough. Any ideas on how I can make the shams hold their shape? Thanks.
dlnw is offline   Reply With Quote
Old 10-26-2013, 03:14 PM   #2
K&B Designer
Live_Oak's Avatar
Wrap quilt batting around some of the inserts that you tried. It's a quick and easy way to bulk them up to make them more robust. If the fabric itself is really too lightweight, it may not really have enough body to be used how it's being used. A lot of the budget "bed in a bags" use too thin fabric like that. There's not a lot of help for that unless you're willing to remake everything and add interfacing or a lining to it.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-26-2013, 03:54 PM   #3
Great idea! I can just keep adding and stuffing into the corners until it holds the shape. Thanks!
knuckles, elbows, base inserts, crown inserts for bullnose corner bead drywallfinisher Drywall & Plaster 1 05-18-2013 04:30 PM
Can you wash a pillow? tibberous General DIY Discussions 9 10-29-2012 09:55 PM
Threaded Wood Inserts for Gutters kkbayers Roofing/Siding 6 06-25-2012 02:23 PM
screen door inserts markie28 Windows and Doors 2 05-30-2011 07:56 AM
Grant to replace w/vinyl window inserts. Worth it? dirtyp Windows and Doors 1 03-09-2011 06:41 AM
