Picture Framing My Flatscreen Tv? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-05-2011, 04:05 PM   #1
picture framing my flatscreen tv?
I just got a 60" lcd tv. My wife wants me to frame it like a picture. I've got pics of what I want it to look like but was looking for ideas of how to secure it to the wall, but still be able to take it off easily if I need to access the back to add more cables. Has anyone done this or have a good method?
Yeti is offline   Reply With Quote
Old 12-05-2011, 04:10 PM   #2
DIY staff
Rewards Points: 7,174
Most times those are hung on a bracket that tips forward at the top----Have you got any ideas?
Is perfectly flat against the wall O,K.?
Will cords and plugs clear the wall if you just hang it flat and don't use a bracket?
Old 12-05-2011, 04:35 PM   #3
I'm going to get a mount that puts the tv as flat against the wall as possible. I'm thinking now that I can put a couple angle brackets on the wall and have a pocket in the back of the frame that will slide onto the angle brackets. This way I can just slide the frame straight off if I need to access the cables in back.
Old 12-05-2011, 04:44 PM   #4
DIY staff
Sorry===I thought the t.v. was the question----The easiest thing to hand the box/frame--is a long wood cleat---with a 45* bevel cut into the top---gap to the wall -pointed part out--
Then add a matching 45 beveled strip to the inside top of the box/frame--
That box will simply hang off the cleat--nice and tight and lift off easily.
Old 12-06-2011, 06:04 PM   #5
tv cabinet
There are many options for flat screen tv cabinets. you can google for images of ideas and show her to see what she has in mind. i have on around my 50 inch plasma and love it!! here are some ideas.
picture framing my flatscreen tv?-tv-cabinet.jpg   picture framing my flatscreen tv?-tv-cabinet-2.jpg
teepee105 is offline   Reply With Quote
Deck framing for mitered deck planks corners jim-in-ga Building & Construction 11 12-08-2011 04:37 PM
Basement Framing ddave23 Building & Construction 4 10-30-2011 10:38 AM
Framing Nailer of Death! Oh-Fudge Tools 6 09-15-2011 09:11 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 09:12 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
