Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-14-2012, 01:26 PM   #1
Picture Frame Wainscoting Layout help
Hello,
I was hoping I could get some help/ideas on the appropriate way to layout picture frame wainscoting for a baby room. I was hoping to get the same shape "picture frame" look all the way around the room, however due to the walls having different lengths I don't believe this will be possible.
I just want to make the look as uniform as possible.
I've attached a graphic with what I've come up with, but I'm open to suggestions to make it more uniform.
blobula is offline   Reply With Quote
Old 11-14-2012, 05:24 PM   #2
sdsester's Avatar
What about two, longer, more horizontal panels on each wall with the spacing in between the same and on the ends?
Continuous, not picture framed, wainscoating is out of the question? Tufted upholstery fabric and not wood?
sdsester is offline   Reply With Quote
Old 11-14-2012, 06:11 PM   #3
I think that what I'm going to do is two longer horizontal frames. The frames on the right wall will be 3ft long and the frames on the front/longer wall will be 5ft.
I'm going for a similar look. See attached.
Old 11-15-2012, 12:53 AM   #4
sdsester's Avatar
Again, I would aim for the spaces between the "picture frame" trim to be the same distance all the way around the room. That becomes the unifying element. I think then, even though they are a different size, the panels will look fine. You would expect them to be different on different walls.
Just curious how this will work out on the wall with the door? I guess one panel of whatever size on either side of the door?
Looks like it will be a very nice room. Please post a picture of the final product?
Diy picture frame light sack17 Interior Decorating 2 05-16-2012 09:58 AM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 03:05 PM
New window in old frame KurtP Building & Construction 0 09-12-2010 11:10 AM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 09:26 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
