Painting Wall In A Room With Vaulted Ceilings - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-31-2013, 07:18 PM   #1
Rewards Points: 37
painting wall in a room with vaulted ceilings
my wife and i are going to paint my home office. the previous owners had an interesting choice of colors and its time to change it. the colors are going to be light grey/silver w a navy blue accent wall.
the thing is the room is vaulted and im not sure if i want to paint all the way to the ceiling. the previous painted only to just above the doors. would it look silly to do it that way or shoud i just paint to the top?
need some design help please
here is a pic of the room from the home listing. Everything is gone except the color. My furniture is a rustic/modern wood desk with a white immitition herman miller leather chair.
thoughts?
joshik is offline   Reply With Quote
Old 07-31-2013, 08:05 PM   #2
firehawkmph's Avatar
Rewards Points: 1,868
Moderator, how bout fixing these ads and blogs!!!!!
Josh,
I wanted to answer your post but those g$%% d###$d ads and blogs are covering up half the picture and the words. I wish the moderators would get on the ball and fix this problem.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
MollyBean (08-31-2013)
Old 07-31-2013, 08:31 PM   #3
Too Short? Cut it Again!
Why not post real pictures of what you have now. And may we see the cathedral ceiling you mention? A floorplan showing all windows would be helpful too. Sweet Home 3D is frfee.
Old 08-03-2013, 07:38 PM   #4
Rewards Points: 4,796
That is kind of an interesting idea - to keep the vaulted area white. However if I did that, I'd probably
a) raise the paint up about a foot
b) put in some sort of molding to section it off. Paint lines on walls look a little cheesy without molding or something to border it.
jeffnc is offline   Reply With Quote
Old 08-04-2013, 07:37 AM   #5
Bill Kearney
Rewards Points: 1,174
A ring of crown molding would also serve to make a nice boundary.
How does the vaulted area intersect with the rest of the house? Is there a balcony or something else "up there" looking down into this area? If not then you might also consider putting some rope lighting in the crown. Well, you could do the lighting even if there's an overlook, just that an open crown with lights in it would be more visible than, say, one done with a closed top.
wkearney99 is offline   Reply With Quote
Old 08-04-2013, 07:56 AM   #6
Rewards Points: 2,634
I agree with the previous posts that you at least need some molding to separate the two colors. I would just make it one color. You have been living with that room for a while, so to you, it perhaps looks natural that way. But to me, the only statement that color scheme makes is "it sure is a lot easier to only paint seven feet of wall"
SPS-1 is offline   Reply With Quote
Old 08-05-2013, 07:10 AM   #7
Rewards Points: 6,185
wow, what a nice look with the white on top. It looks sharp and clean
and unique.
I would end the color right at the top of the door and window...no molding separating
the two paint colors. I'm not a fan of accent walls, so I would
do the entire bottom half of the room the silver grey.
If you want to bring in navy in the room...do it in the accessories, and or the furniture as well
as the artwork.
Two Knots is online now   Reply With Quote
Old 08-05-2013, 02:13 PM   #8
Bill Kearney
Without molding to separate you end up with noticeable defects where the colors change. Molding helps take the eye away from noticing that sort of thing. That and different styles can offer different effects on controlling how the height of the room is perceived.
Ending the color any lower than where it is currently would be a mistake. You want a certain amount of matched sizes for borders like the areas around/above doors and windows. Too low and it makes the color look short, and the ceiling too tall. Too high becomes an issue with the area above windows/doors looking like an awkwardly sized, but useless section of wall. I'd venture that between 12" and 20" is about the right range.
Old 08-05-2013, 06:28 PM   #9
Joshik, what is rustic modern furniture? Is it dark?
Do you have an example or a pic of the furniture?
I like to dress up the tops of windows (that don't have window
treatments, such as drapes) with mantles, and closets and doors
as well...Would you be open to that suggestion, just dressing
up the tops of the closet, entry door and window, and
ending the paint there, without molding all around the room?
If so, I could show you a couple of examples.
The extra trim on top of the window
and doors would raise it up a few inches, and give you a
line where to end the grey paint.
One thing great about a forum like this is -- you get
various opinions on your question...You then have the right to
take what you want from it, and ignore the rest.
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Need suggestions for living room wall color. jillybean1 Interior Decorating 9 05-16-2009 06:18 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
