Painting Clue What I'm Doing! - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-04-2008, 08:01 PM   #1
painting clue what I'm doing!
I recently decided to repaint the basement in my house..i use it mostly for when i have parties so I'm not looking to upgrade the furniture but just want it to look a bit nicer with some new color. Any advice as to what color I should paint is welcome. I am also planing to use swp or b. moore paints... if that helps. Thanks!
about the attachments... the first (006) shows the area with my couches.. there is a window to the right of the couch seen at the bottom of the picture. Youll notice that I still kept my college decoration skills.
on picture 007 you will see the other side of the room with the window on the left hand side. In this area where i have the german flag I am considering installing some cabinets to make a "bar" area.
So again have a look and i appreciate any advice, Thanks!
mark415 is offline   Reply With Quote
Old 02-24-2008, 10:50 AM   #2
WOW, your basement is packed full of furniture!!! A bit too much IMO, but hey, that's just me.
As far as paint color, it's going to be kinda hard to make a call on that considering you have a shmorgasboard of furniture with no set color scheme. You've got the shiny leather as well as the plaid, which do not go together whatsoever. I know you said that you weren't replacing the furniture but I had to give my thought to you on that. The only thing that I would say is to compliment your walls to the color of your carpeting. Sherwin Williams has a great color called "Escape Gray" It looks green in some lights, and in others it looks gray. I think it would look nice in your basement.
polar5554 is offline   Reply With Quote
Old 02-28-2008, 02:50 PM   #3
Born a decorator
PassionateDIY'er's Avatar
It has to be a light paint color to keep it bright in a basement. Gray may be a good choice, but I think you should go up a notch or two on the color card Austere Gray or Conservative Gray.
Last edited by AtlanticWBConst.; 02-28-2008 at 04:57 PM. Reason: Advertising Links Removed
PassionateDIY'er is offline   Reply With Quote
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
DIY Basement Painting scottmatt Painting 14 06-09-2007 09:51 AM
Painting cement basement ?'s Dusty Painting 3 09-29-2006 05:27 PM
