Oriental Rugs? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-11-2009, 06:06 AM   #1
ccarlisle's Avatar
"Where can I find Oriental type rugs"?
Walmart.
"How can you tell the difference between machine-made and handmade rugs?"
From the "Made in China" tag...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 06-11-2009, 04:57 PM   #2
Originally Posted by eric21wno View Post
Where can I find Oriental type rugs.How can you tell the difference between machine-made and handmade rugs?
Thanks!
Without a lot of experience I'd first talk to local suppliers and ask the difference.
Actually, If you searched ebay and took the time to read the descriptions that some of the larger importers have it would be a help as well. I have close to a dozen rugs, all different sizes and KPI, (knots per inch) as well as thickness. Higher KPI = higher cost and usually higher quality and wear resistance.
There is a huge amount of info from experts on the net as well. I'm no expert and the rugs I have range from inexpensive to the other end of the spectrum.
Last thought, I've found quite a few deals at estate auctions. A very good rug that's 60 to 80 yrs old may have very little wear but the colors are rather bland. Brighter more vibrant colors are rare in older Persian rugs.
Shamus
Shamus is offline   Reply With Quote
Old 06-18-2009, 01:16 AM   #3
Thanks!
Oriental rugs are very famous for there quality an design. You can check out these site i am posting here: ,
4 Things will differentiate hand knotted rug with machine made ones:
Price
Hand-knotted ones are high priced ones while machine made are cheaper.
Fringe
If the rug has a fringe, its characteristics usually gives it away if the rug is handmade or not. A simple thing to look for is this: Is the fringe sewn over the rug or was added to the rug as a finishing touch or is it an extension of the rug? If it is sewn over, it is a machine-made. If it is extension of the rug, is handmade.
Edge Finishing
Another easy way to tell the difference is by looking at finishing used on the edges of the rug. If binding or serging is used, the rug is machine-made. Handmade rugs (knotted) are always finished on the edges by hand which looks like serging but you do not see the machine stitch tracks on the back
Back
One of the best ways to tell if an area rug is handmade or not is to look at its back. Inspect the back closely when looking at weaves or knots. In handmade rugs, they are slightly uneven, a sign of imperfection while they look perfectly even in machine-made rugs. Hand-Tufted or Hand-Hooked rugs (made with gun) have a cloth backing and the edges normally don't have a finishing such as binding.
Hope this explains.
Dana11 is offline   Reply With Quote
