Not Sure What Color To Do Molding In Bath - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-05-2013, 02:46 PM   #1
Not sure what color to do molding in bath
My walls is painted very light gray. My vanity cabinet is oil bronze and granite top. Floor has differant dark colors of gray. I want to do dark trim, but it is a small bath and I want to look bigger. Please give me some suggestions please. Thank You, Betty
zowie is offline   Reply With Quote
Old 08-05-2013, 04:15 PM   #2
mrs fix it's Avatar
😁what are the colors of the rest of the trim in house, a picture is worth ten thousand unspoken words 😉
mrs fix it is offline   Reply With Quote
Old 08-22-2013, 08:05 AM   #3
As you said that the bathroom is small then don’t go for dark color . Choose a light color matched with the vanity and wall color. You can also use the color used in the rest of the trim in the house. It it is matched with your vanity . If you want to use dark shades, make sure that the sufficient amount of light source is there.
hudsonkelvin is offline   Reply With Quote
Old 08-23-2013, 12:14 PM   #4
Rewards Points: 274
Select some light color that will make house spacious.
alexjoe is offline   Reply With Quote
Old 08-23-2013, 12:52 PM   #5
White is the best.
leenamark1 is offline   Reply With Quote
Old 09-06-2013, 10:02 AM   #6
Since you said that your bathroom is small, If I were you, I wouldn't go for dark colors because it will only make your bathroom look smaller. I suggest white or light colors like light blue, etc.
emilyharper is offline   Reply With Quote
The Following User Says Thank You to emilyharper For This Useful Post:
DIYHomefit (09-09-2013)
Old 09-09-2013, 12:50 PM   #7
@emilyharper - exactly what I was thinking! Also, if you ever decide to redo your bathroom, then light colours like magnolia and white are the safest options.
DIYHomefit is offline   Reply With Quote
Old 09-09-2013, 03:37 PM   #8
Controller
I wouldn't do it the same color as the vanity. Are there windows in the bathroom? And are you just talking about the floor trim? White or a light cream color could work. A dark color could work, just make sure it's not the same color as the floor (or too similar), as that could make the walls look shorter than they actually are.
One way I like to make rooms look bigger is to paint one wall a different/darker color than the rest. Just make sure it's not the wall with the window (if there is a wall with a window). And I wouldn't paint the ceiling dark. That always makes rooms feel smaller in my opinion.
Another way is to add a mirror, though since it's the bathroom you probably already have one.
Sacramento Pest is offline   Reply With Quote
Trying to remove base molding h22lude Flooring 3 05-29-2013 01:59 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
