Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-20-2009, 11:09 PM   #1
Noise/echo Reduction
Hey guys, I just moved into a college apartment with two roommates. The whole apartment has stained cement floors, and the bedroom/bathroom doors have a 1-1.2" gap under them. The problem with this combo is noise. You can hear my television 40 feet away in the furthest room from me, and what not.
What are some things I can do that won't look tacky to cut down on the echo, and on general sound travel under the huge gap under the doors? I've bought some curtains and a rug for my room to reduce echo, but mainly what can I do about the gap under my bedroom and bathroom door?
thanks guys!
aaron_c is offline   Reply With Quote
Old 08-29-2009, 10:50 PM   #2
The hardware shop should be able to sell you a door sweep that you attach to the bottom of the door to make the door touch the floor. Usually their used for outside doors to ensure that the gap does not let in cold air, however, in this case, you might be able to use it for blocking sound. Another idea for sound proofing is using old ceiling tiles on the wall as a bulletin board. You could cover them in posters or a fabric. They deaden any type of noise.
Tsal is offline   Reply With Quote
Old 09-22-2009, 04:32 PM   #3
Since you're in college (hence very likely broke) I'm going to go ahead and recommend the towel under the door approach. This should dampen the echo slightly and might have some other uses too
Last edited by AtlanticWBConst.; 09-23-2009 at 03:02 PM. Reason: SITE RULES VIOLATION: Advertising Links Removed From Signature
Plumb And Light is offline   Reply With Quote
Old 09-24-2009, 05:41 PM   #4
You may not be able to drill into the doors if you want your deposit back. They sell those long rods of foam at toy and other stores if you don't want to fuss with a towel and need something rigid. I don't think they are very expensive and you could cut sections to whatever length you wanted. Find someone to sew you some covers if you want to dress them up. They also sell those insulation socks that go along the bottom of doors.
College student apartment you said? You might try turning the televisions and stereos down? What does Plumb and Light mean by other uses?
sdsester is offline   Reply With Quote
Old 09-24-2009, 08:59 PM   #5
Remodeler
KlintP's Avatar
What about something like this:
http://www.amazon.com/BRAND-NOT-SPEC...ef=pd_sim_ol_1
Or one of the other "Draft Blocker" products.
KlintP is offline   Reply With Quote
Old 09-24-2009, 09:33 PM   #6
The large gaps under the doors might be necessary for the heating system to work properly. If you only have vents blowing air into your room, then the gap is needed for air to return to the furnace. A less permanent solution such as a towel is then the ticket. If you have a vent that you can't feel air blowing out of, then it is probably a return and you should be okay blocking the bottom of the door. If there are no vents, only radiators, you should be okay as well.
If the door is particularly thin or ill fitting you would gain more noise reduction from foam seals around the door or ceiling tiles on it.
PerpetuallyRepairing is offline   Reply With Quote
More On This Topic
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
After years and years of research, there is overwhelming evidence that smoking cigarettes, in general, is a health hazard that contributes to numerous respiratory and cardiac ailments, and secondhand smoke can be equally as dangerous. Secondhand smoke... Read More »
Fuel savings from burner/nozzle reduction EfficientCanuck HVAC 13 03-01-2009 08:21 PM
Noise Reduction of Original HardWood Floors artist082483 Flooring 2 10-09-2008 05:57 PM
Flex Duct Reduction mwhiting0402 HVAC 3 11-03-2007 02:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
