Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-30-2012, 01:30 PM   #1
Needs Ideas on Updating Frame on Large Mirror
Looking for ideas on how to update this dated looking mirror frame without totally removing and re-framing it. Attached are photos of the mirror frame and also the sconce next to it. Mirror is currently not on wall, but attaches with homemade brackets that are on the wall and on the back of the mirror (looks like thin sheet of plywood is on back of mirror, see pic).
Thanks for any ideas.
Needs Ideas on Updating Frame on Large Mirror-photo-1.jpg   Needs Ideas on Updating Frame on Large Mirror-photo-3.jpg   Needs Ideas on Updating Frame on Large Mirror-photo.jpg
ann99m is offline   Reply With Quote
Old 12-31-2012, 03:19 PM   #2
Stuck in the 70's
Blondesense's Avatar
If you are unwilling to re-frame it, you're pretty much limited to paint.
I did this lamp piece with two colors. I applied the gold first and let it dry. Then I applied the green but wiped most of it off while it was still wet.
It would work on a textured frame like yours.
Old 12-31-2012, 03:35 PM   #3
Thanks. Maybe I could do something like that to at least update the colors.
I was wondering if I could fill in the pattern and then paint it. Maybe a paintable caulk or speckle type of filler.
Old 01-04-2013, 04:06 PM   #4
I think you would be crazy to spend all the time to try to fill in the frame. I recommend spray painting. I think you will be surprised with how it will look completely different.
klmeenan is offline   Reply With Quote
The Following 2 Users Say Thank You to klmeenan For This Useful Post:
ann99m (01-04-2013), joecaption (01-23-2013)
Old 01-04-2013, 04:12 PM   #5
Thanks. We have already primed it and even that is much better!
Old 01-04-2013, 04:13 PM   #6
Or just buy a new mirror. There cheap.
Old 01-23-2013, 05:10 PM   #7
Obsessed DIY'er
You could tape it off, and spray paint it for sure! If you are wanting to give it a little bit of a distressed look or at least highlight the pattern you could try using a product called "rub and buff". Here's a link to the product from Amazon. This one is silver, but it comes in other finishes as well. I suggest google the product and search for images. That might help you better see if it's right for you.
http://www.amazon.com/Rub-n-Buff-Sil.../dp/B000FGEG86
Ellora
http://creativelysouthern.com
CreatvlySouthrn is offline   Reply With Quote
Old 01-31-2013, 01:04 PM   #8
yummy mummy's Avatar
I have a frame that has an intricate pattern like yours. I spray painted it a gloss black, and looks amazing. You wouldn't think so, but it gives it a modernish goth look......lol
yummy mummy is offline   Reply With Quote
Tags
frame, mirror, update
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
going to make mirror frame/edges out of crown molding or baseboard - dumb idea? joeyboy Carpentry 6 11-12-2007 08:39 AM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General Discussion 18 08-10-2007 11:04 AM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General Discussion 11 08-04-2007 07:01 PM
mirror frame jdwdwd Carpentry 3 03-31-2005 10:34 PM
