Need Ideas: Room With 1 Solid Wall... - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-10-2009, 09:14 AM   #1
Need ideas: room with 1 solid wall...
I have a small sitting/living room with one solid wall (9 ft9"). The opposite wall is an entry.
The other 2 walls in the room are 13'9" but one has two vertical windows which break it up and the other 13'9" wall has a large opening leading to a familyroom.
I am looking for ways to furnish this room without it appearing to crowded.....anythoughts?
duetchkey is offline   Reply With Quote
Old 10-10-2009, 09:22 PM   #2
My living room isn't exactly like yours but I did run into a problem with too many windows that would be blocked by furniture. I did not want to have the sofa away from the walls because it became too crowded. I put a sofa table in front of the windows (just out a few inches so there's room for the curtains) and then the back of the sofa right up against the table. That way there's only about two feet between the sofa and the windows but the table provides a "spacer" so the windows don't look blocked.
In another awkward room I put the furniture on an angle and put a floor plant behind the couch in one corner and a table lamp in the other. This really gives me less space but it seems less crowded than having furniture in the middle of the room.
LD004643578 is offline   Reply With Quote
Need ideas for ugly half wall cynwil710 Remodeling 12 08-18-2011 02:34 PM
wing wall demo-post ideas? keoki Carpentry 11 07-01-2008 08:28 AM
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 03:18 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
