Need Ideas, Guest Bedroom Bed/Headboard with windows in way
Assuming you must put the bed against that window, I would get as low headboard as possible to cover as little of the window as possible.
I'd also put a high curtain rod over the window with sheer panels or silk panels on either side of the window. And center the bed on the window. The window and panels would almost act like the headboard.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. residential To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
