Need help in re-designing tiny 1920's kitchen!
5K views 21 replies 7 participants last post by  PiscesWoman
I'm a newbie to this forum, but I desperately need help in designing my kitchen! I have a galley kitchen, with a door to the outside on one end, a door to the dining room on the other, and one to the basement on a third wall. The first pic is looking into the kitchen from the dining room -- I'm considering tearing down the walls between these rooms so I can have a bigger kitchen. The second pic is of the kitchen counter on the right if you're looking into the kitchen from the dining room. The third pic is taken while standing @ the back wall and looking into the dining room. I'm thinking of knocking out the back wall and putting in a pantry/laundry room (my laundry room is currently there but accessible through another entrance).
I need ideas on what to do if I tear down the wall, and what the layout would be. I'm wanting to move the basement door to empty out into the dining room (you can see it off to the right in the 3rd pic); the stairwell into the basement will be straight as opposed to curved, as it is now (into the kitchen) -- so I'll have that space there available. I also have a small pantry next to the fridge now (it's red and in the 3rd pic) and behind it, the chimney juts out a little into the kitchen space (but the pantry isn't as deep as the fridge is, so it lines up perfectly).
Ideas, anyone?
#7 ·
Have you ever thought of working with an architect or even a real interior designer that know a few. Trust me, both will save you money and you will love the experience.
You cannot and should not be allowed to move load bearing structure without drawing and sign offs. You will need permits.
#4 ·
It doesn't look like the wall going into the dining area is load bearing, as usually the rule of thumb is load bearing walls are more than 4 inches in width. That doesn't mean it does not help with a load, especially in older homes.
I wish I knew what that area along your fridge that juts out was. What is behind that wall?
AS far as your basement stairs, you need to measure to make sre your staircase won't be too steep once you straighten it out. If you have room at the bottom, that should not be a problem.
If you decide to take the wall out to the dining room ( which I think is best} make sure there is no pipe, ductowrk or electrical in the wall by carefully removing. Don't plow through it like they do on TV. REmove a section at a time.
You could put a penisula from the kitchen to the dining room once the wall is down with some cabinetry underneath. You could use top cabinets that are 12 inches wide if you would want to have extra storage for both rooms. Put them back to back so doors are facing both the kitchen and dinind area and use veneer to clean up the sides. You can build a base to whatever height you want the penisula to be.
Make sure you secure the top portion of the wall you remove for safety sake. If there are pipes or duct work wrapped, be careful, as it most likely will contain abestos. I had a 100 yr old house, and the person who said you can be opening a can of worms could be right. If you love your house and plan to stay and need it to function better or just look better and work better for you, then I say go for it! Just do yourself a favor and price everything out and add 30% if your house is older than 30. THat contingency should do you well. With any luck, you won't need it and can use it for a vacation afterwards!!
Good luck!!
ps- no what you hear...stay away from laminates in the kitchen for flooring. THey do NOT hold up to water well!!
I think that porduct is only good for "show" kitchens. It's not a durable product.
I also suggest you don't go too trendy. Things go out of style too quickly and then it looks dated. Wood is timeless, and so is white for kitchen cabinets. I picked colors for cabinets, granite and flooring when redoing mine that were " nuetral". This allowed me to change my paint colors, table and art work without a hitch and keep my kitchen up to date through the years. It can be a costly adventure, so think wislely when picking your products!
#5 ·
Ok... (deep breath)
I've talked to a few contractors, and they think the wall between the dining/kitchen IS a load-bearing wall. I know that limits me.
"I wish I knew what that area along your fridge that juts out was. What is behind that wall?" What do you mean? My basement door is next to my fridge, on left side, then you have the fridge with built in shelves on top, then the chimney that juts out a little bit, and the pantry sits in front of the chimney. If you're looking @ the third pic, the cabinet that you see to the near right is a recessed spice cabinet fitted in between the studs; behind that wall is the hallway to the back bedroom, which also contains the laundry room entrance.
I had thought about a peninsula or snackbar where the wall would be removed. But if I straighten out the basement stairs, the door would open right next to the peninsula -- in between the peninsula/counter and the dining room wall.
What about the space where the basement door was, once I move it? In the third pic, you can see that I attached a fold-down wooden table to the wall, for extra space when the basement door is closed. If that wall is removed and the door is moved to the dining room, I leave an open space that looks directly at the side of the fridge...
We really need more prep room. Pic #2 shows ALL of the prep room we have on counters (not including the aforementioned fold-down table). I thought about a butcher block island where the red pantry is, as a dedicated place to prep veggies, since I can't move the fridge over to the right (due to the chimney jutting out)...
And yes, the laminate will be going bye-bye too! I am considering cork or bamboo...
#8 ·
Even if it's load bearing you can widen the doorway.
You did not mean to the post this did you? :no::no::no:
You cannot and should not be able to casually widen door space under direct load bearing structure.
Yes you can make it work. You will need an architect or structural engineer to help though. One may be willing to sign off on drawings for new headers and reinforcement to the basic structure.
#10 ·
So the dark wood door on the right side of your fridge in # 3 in the pantry?
How deep is that? What is below and above that door? From what your'e saying, the chimney is behind it. I know that's a cool, original feature, but if it goes all the way up and down inside of the pantry area, you may be able to gain valuable space for storage there as well.
You need to talk to the building department in the area you would get your permits from. If you know what you're doing, you can submit plans yourself.Why not consider making a pony wall? open the top portion of the wall, put a steel header in for support with a beam on the side coming down along the side where your doorway is now? You CAN remove a load bearing, but it is more difficult for that reason...it bears the load of your top floor and/or roof.
You could still add cabinets or shelves to either side of your pony wall, and buy a nice piece of 1/4 plywood to cut, stain or paint and dress up the side, and cap off the ends with corner wood. You can add a countertop of your choice, and make it come out far enough to allow for a few stools.
It does seem a bit dark, but those kinds of things are a person's personal taste. A lot of people are oppossed to painting wood,( I'm included in that group!) but I would consider painting my cabinets white in order to lighten it up in the room. White is a very classic color for a home this age. I love the look of carerra marble with white cabinets in homes of this era, but carrera marble is not the most practical in a kitchen to me, as it has a tendency to stain even if treated regularly.I have always tried to keep in mind the age and flavour of my home when making any changes, but again, those options are up to you. There are so many products out there nowadays.The contertops they make now out of recycled glass are pretty awesome looking, and can add pops of color without overwhelming it with color. I have granite. I cut on it, and I love it! I treat if every 8-10 months as I use my kitchen counters a lot, and I've had them for years and they are great. I looked around and found a great deal and am very happy to have spent the money on them. THree times I changed my mind on the granite color. These are not easy decisions.They cost time and money and energy. All things that are not replaceable.
I would also add puck or pendants if you decide to take down a portion of that wall.
These are not easy decisions. Trust me, I've been there many times. You need to decide how open and airy you can live with and what will make you most happy.We gave up a bedroom alongside our kitchen to expand and I never regretted the decision. I love having the openess to be able to talk with family and friends while I am in the kitchen. For me, it was worth it all in the end. If that is why you chose to do this, I think it is a wise choice and a wise investment. At the end of day, it's YOU in there.
You may want to talk a realtor in you area about your ideas and they will be able to tell you if and how much it can increase the value of your home.He or she may also know people locally who can assist you with this project.
Keep us posted!!:thumbup:
#11 ·
Drawings, architects, interior designers? Eek. Google your options, go to hgtv for example. You can put a header in if removing a doorway. Geez. If you have seen any amount of DIY thats one of the first things they look at is opening up rooms, because they want the open floor plan. And yes they consult a licensed contractor but a architect, drawings etc. most of us do not have that extra expense in our budget.
#12 · (Edited)
The expense has to be in your budget.
Unless working under cover of darkness, you cannot change central structure anywhere I have lived without drawings, signoffs and inspections. I worked with architects and structural engineers all the time. I don't remember paying more than I would any other people part of the project. And they showed up on my jobsites.
You cannot simply remove a beam, or sister it in the middle of something load bearing and header a door because you want one on structure holding your house up.:no:
What dangerous nonsense you suggest. :huh:
Do not get me started on HGTV type shows. I have been banned from watching Design on Dime. And the chick that paints in heels making houses look nice for sale? Really scares me even if she was Miss Canada once or something. Nobody I know paints in heels.
#13 ·
Janetp -- the dark red wood on the right side of the fridge is my pantry, and I'd say it is about 1ft deep. The chimney is behind the freestanding pantry, and runs up and down the entire length of the wall.
I'm going to have to look into this pony wall -- I've never heard of it! Do you mean a half wall? Leave the door as is and put in, like a snack bar or something like that? I could make the countertop higher in the kitchen to accommodate work space, and lower on the bottom portion in the dining room for some stools and cabinet space underneath. However, guests would still be looking at the side of the fridge when sitting at the counter. I'd also like to have some more room next to the fridge so I can get a bigger fridge.
As far as the color goes...I've painted the cabinets a light cream, and painted the backsplash a shiny yellow/orange, but I'm still unsure about that. I DO want to get granite or butcher block countertops anyway, but not sure what to do about backsplash. If I get granite, I'd just extend the granite as the backsplash, creating a seamless transition.
I've got plans to add lighting SOON -- the weekend after Easter, actually. I am putting in a light @ the backdoor, matching the current light (both stained glass semi-flush lights). Then I'm putting a recessed light over the sink, and a long, skinny, pendant light over where the new island will be (i.e., where the red pantry is in the pic -- now it is cream colored :) )
Thoughts?
#16 ·
Nope. Straight back, behind that back wall, is the laundry room; it opens up into a hallway. I plan on sealing off that entry, and putting a door with frosted glass on that back wall, making the laundry room into a laundry/pantry room with under cabinet washer/dryers and wall cabinets/shelves...
#17 ·
You might want to look at my thread on renovating our kitchen/dining/living area. We opened up a load bearing wall between our kitchen and dining room to turn it into a bigger airier space. I'm still doing a ton of finishing touches, but it was well worth it.
When you remove/modify a load bearing wall, you need a structural engineer to design a plan. They come in, determine what the wall is supporting in terms of load from the upper floors, what is supporting it beneath, and what you need to do in order to distribute the load over the new wider opening. They give these drawings to an architect who in turn creates suitable plans that you can get a permit with.
If you take out the wall you'll need to support the opening with a new beam, either steel or what is called "engineered wood" This can hidden in a soffit or in some way integrated into the design. Each end of the opening will have a post strong enough to take half the load on the beam, and these posts in turn need to be properly supported underneath, which can potentially mean a new footing in the basement and a steel post directly underneath.
It all sounds terribly complicated but it is not. You build temporary support walls on either side, demo the wall itself, install your new beam and supports, then take down the temp walls and you are done.
When I opened up our wall the only surprise was a couple of radiator supply and return pipes going to the radiator in the bedroom above. Took a plumber a few hours to reroute them.
As far as planning your kitchen goes, I highly recommend 1) using the IKEA kitchen planning tool on their website, and 2) going over to www.ikeafans.com and posting in the forums there, even if you are not considering IKEA stuff at all. Kitchen design is kitchen design no matter what cabinets you use, and the tool is very useful and the people at that forum are super knowledgeable about designing kitchens.
#18 ·
Ironlight, you did an amazing renovation on your cradtsman home.
The kitchen is gorgeous as well as everything else. I would love
to see more pic's of your home. I admire your careful attention to detail.
I was going to suggest to Pisces to make a wall of windows on the
back wall to let in the light. She could look at your kitchen photos
for inspiration.
Pisces, When you open the wall between the rooms, it will totally
change everything as far as planning a new kitchen,
I have a galley kitchen so I can appreciate your situation.
#19 ·
Thanks. I finally finished the backsplash in the kitchen last week, and now need to get to work on the built in bookcases that will line the long wall in the adjoining "family room".
I want to put in another plug for removing walls in old houses. It makes a huge difference in how the space works and how you live in the house. Yes, the cost of the engineer and architect is perhaps more than you want to pay, but opening the house up can also add significantly to it's value and gives you much more flexibility in designing the kitchen itself. I would definitely do it all over again, although I might not do it myself! Or at least I would hire people for certain parts of it...like the drywalling and painting.
#21 ·
Sorry, but I've been re-doing my hardwoods:laughing:
the town I live in has a guy in the building departent that you take your plans to and if he likes what he sees it;s approved. If he doesn't he'll tell you want he wants to see most likely to get it approved.They come and check step by step to make sure it's done correctly and that's why you pay for permits, but we made a pony -or half wall- on a bearing wall in another house. It was a long time ago, but we rented jacks that supported the wall on either side while we removed the wall, and My hubby made braces out of 2x4's to support as well while we got a steel beam up there and secured it. THe braces he made were like a rectangle going from the ceiling to floor, with 3 or 4 pieces of 2x4's in the middle to make it sturdy. His buddy secured the beam, so I can't tell you that, but I know we coved it with oak and stained it and it looked nice.Once it was up and secured, they removed the jacks and the 2x4 support. THe roof never fell, and no cracks occurred our plaster walls either. Where there's a will.......
Don't let some of the comments you've had get you down.People take some of the shows too seriously. It's a friggin' tv show, so of couse they are going to look like models. Who cares, really. Personally, I have a friend like that. She looks like she's ready to go on a date and she's cleaning the garage or doing gardening. God bless her!! I look like a slob when I do these kinds of things, as I think most of us do. Different strokes. If we were all the same, it would be a pretty BORING world. As far as hiring an artitect or designer, let's just say my goose died so there are no golden eggs for me to cash in anymore. If your goose died as well, do the best you can with what you have.
When we first bought this place the kitchen made your's look like a palace!! I had nasty tiles as a back splash, with many missing. You know what I did?? First, I cleaned the hell out of them. I bought some grout and gently leveled out the lines after sanding them a bit so the grout would stick. I found a nice roll of vinyl wallpaper...yes, wall paper.... and I covered it the lengthwise, so chose a pattern that works that way if you try this. I was lucky and I didn't have to seam it as it was about an inch wider than what I needed. Most wallpapers are 21 inches wide. I caulked it where it met the counter top and it lasted me for 6 years til I finally had the money to change it all out the way I wanted it to be. My hubby bought a piece of plexiglass and we put it on the portion by the stove where you are most likely to get grease.
I liked it so much i bought 2 more rolls and a chair rail to divide my wall up and did the bottom half of the kitchen in the same pattern.
Is it possible to move the fridge? Maybe to the back , like where your pots are hanging, but facing you? You could maybe put in a lazy susan in the corner and have your counter go around and meet into the straight portion of your counter. I was counting tiles on your floor to see if you could possible have enough space for that, but you can measure. I helped my friend lay granite pieces that were 12x12 as her countertops. She used black. We kept her existing counter and just removed the laminate on the top. It was a pain to do, but then we cleaned with a solution made for removing glue, and laid the black granite, leaving just a tiny space between so there would be hardly any grout line. We purchased a black epoxy grout and it looks amazing. I have a wet saw, so we were able to keep the cost down by not renting one. She used small black mosiacs for the edges and it looks really good.We put the side portions, the edges if you will, on first. This way when we started with the larger top pieces, we could make sure it lined up to look like one cohesive piece. Her cabinets are white, and we laid a black and white vinyl floor and it looks pretty damm cute with her orange excessories.
I'm not a pro, but I have been a DYIer for as long as I can remember. I have made cutains from sheets, hand painted things onto shelves, picture frames and walls. I have hung cabinets, laid every kind of flooring known to man, refinished a LOT of furniture pieces and hung, bed and taped drywall, painted way too many times and refinished hardwood floors now and in the past as well. I converted an old stereo cabinet into a sink in one of my bathrooms. I made my pot racks over my island by using those chrome/metal racks you buy as a cart, and running chains through the part that the leg would normally go and using a wood dolls head ( it's a round ball of wood) and screwing it with the hook so the the chain could fasten once attached and hung from hooks in our now contemporary kitchen.. Before that, my country looking looking had old wood cutting boards . It's nice because I put the screws where I wanted them. The only thing I don't do is electric and plumbing. Hubby is an electrician and we are lucky to have a dear friend for a plumber.Some of my projects have been fantastic, some not. The thing is you try til you do get it right. Take your time. Patience IS really a virtue!
I have a few friends and family members with houses that mine would fit in. Twice. Every last one has always told me that my house is uniqely my own, and they must like my "stamp", as they ask me for suggestions or a helping hand all the time. My 3 daughters all own, and it made me proud that they not only came to me for opinions on projects, but asked for my help and guidance as well.
Our granite is solid, no seams, as the slab we chose from a local vendor was large enough to the the counter this about 10 ft long, with a corner that extends about 6 ft the other way. No seams. My island is 4x6, and the piece on the other side of my stove is 24'2 ft x2 1/2 feet. It ALL cost me $1,540. If you look around your area, you can find a good deal as well if you want a whole piece. I cut on it, and it is WONDERFUL! not a scratch or blemish. I found them on the intenet. THat price included the cost of thier measuring and installing as well.:thumbsup:
In the end, it doesn't matter if any body else likes it but you. Our home is a reflection of who we are, just like our friends. And you know what? They ALL have flaws. I however, prefer to call it character!!!:thumbup:
#22 ·
No worries. I'm still in the middle of adding lighting to my dining room... :thumbup:
As far as the fridge goes...no it can't be moved to the back -- it's where my back door/access to back yard is, so that's gotta stay open. I definitely like the idea of using a solid slab of granite for the countertops, though, since I just have such a small space to cover.
I'm looking for an island online where I can put where the red pantry currently is. I want it to have a butcher board top, pullout drawer for silverware, and a trashcan space underneath. I think widening the doorway between the dining/kitchen will help to make the kitchen bigger, as well as taking out the free standing pantry.
Do all fridges have the same depth? I want to cut the entryway to be level with the fridge, I think. Then make custom cabs right next to the fridge to the ceiling for more storage space.
The other option would be to put a floor to ceiling pantry cabinet where the current one is, but since the chimney is there, I'd lose depth. In that case, I'd move the butcher block to the other side of the fridge, where the basement door is now, and make the wall adjoining the dining room a half wall. The other downside is that there is a danger of juices/food flying from the chopping block into the dining room...
