Need Better Way To Finish Crown Molding. - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-02-2013, 10:38 PM   #1
Rewards Points: 26
Need better way to finish crown molding.
Hi. Kitchen remodel, brand new cabinets with crown molding. GC guys put back piece of old crown molding but I don't like the way they have done it. It's ending on a straight line and butting on the cabinets crown molding. Picture shows it much better. Any suggestions for a better way to make this look better finished?
Thanks so much
skuba is offline   Reply With Quote
Old 07-02-2013, 10:43 PM   #2
DIY staff
Rewards Points: 7,174
What is that original crown made of?
A shot from further back might help us see---
A mitered return might look better--possibly in the face of the wall before the cabinet end wall---
Old 07-03-2013, 12:15 AM   #3
Rewards Points: 26
Thanks for the reply. Not sure what it's made of. I think it can be wood. The finish on the picture is kind of mittered already against the other piece on the wall it corners with. Unless you mean to mitter it in a different way. I would really appreciate if you can explain it more.
I won't be able to take another pic until tomorrow, but I really wanted to provide feedback to GC first thing tomorrow morning before they will start paint work.
Old 07-03-2013, 03:32 AM   #4
Framing Contractor
Rewards Points: 120
Is that existing crown plaster? We had to do one last year that had plaster crown. We ended up using a larger 2 piece crown and going over the existing. Yours is going to be very difficult to make look right.
sixeightten is offline   Reply With Quote
Old 07-03-2013, 09:44 AM   #5
Rewards Points: 26
Yes, it's plaster. Covering it wouldn't be better since the big issue here is to solve for that small part of the wall where it's butting against the other crown. I am trying to figure out the best way to finish it in a way that it doesn't butt the way it is. I think the weirdest part is that it ends straight while the other crown is curved.
Here are some ideas I mocked on photoshop. What do you think? Other ideas?
Need better way to finish crown molding.-crown4.jpg   Need better way to finish crown molding.-crown3.jpg
Old 07-03-2013, 10:19 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Do you have more of the plaster molding, to do as you have there you would have to extend the molding, but then it still won't work, there isn't enough room for a return.
I hate kill blocks but that would be a good place for one.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-03-2013, 04:45 PM   #7
Framing Contractor
Rewards Points: 120
Somebody has two screen names:
skuba
skubaman
Old 07-03-2013, 05:54 PM   #8
An old Tradesmen
Rewards Points: 7,414
skuba
skubaman
Not anymore.
Old 07-03-2013, 06:00 PM   #9
Rewards Points: 26
I didn't create a second username on purpose. Had simply forgotten I had signed for this forum before.
Anyway, still looking for some suggestions for this problem with crown molding.
What's a kill block?
Old 07-03-2013, 07:56 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Kill block.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
skuba (07-03-2013)
Old 07-03-2013, 10:23 PM   #11
Rewards Points: 26
Thanks guys. Problem solved. They went with one of my ideas and I think it looks good.
Crown molding with window Jeff180 Carpentry 12 07-07-2013 02:46 PM
Crown molding angle question Lavid2002 Carpentry 35 08-24-2012 06:05 AM
Crown Molding install question petros151 Carpentry 31 01-14-2012 10:11 AM
Crown molding - uneven ceiling jelly Carpentry 9 01-05-2010 06:24 AM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 08:32 AM
