Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-05-2011, 03:16 PM   #1
Mount Glass or Acrylic Pane on Wall
I'm making the office space in my house nicer and more usable. I came across an idea to replace my old whiteboard with a Lexan Pane or Glass.
In either case I want to mount the pane on the wall so that there is a small space between the wall and the pane.
So what I am curious about is if there is a why to safely and securely mount a piece of glass in that manner and hopefully have it look nice?
EDIT: forgot to mention that the Lexan/Glass won't be more than three feet wide and two feet high.
khail is offline   Reply With Quote
Old 12-22-2011, 10:43 AM   #2
sdsester's Avatar
If you use lexan you can do an almost invisible install by driving some flat head screws into the wall at the corners and midpoints---measure carefully. Glue tiny (1/16 or 1/8" D) super magnets to the back of the lexan to match up with the screw heads---again measure carefully. Stack them to the desired thickness. Fit the panel in place.
This might work for glass too but it is heavier. You might have to drill it and using a nylon spacer and screw anchors.
sdsester is offline   Reply With Quote
Where can I purchase a decorative acrylic shower surround wall? happygal27 Plumbing 2 06-29-2011 01:16 AM
double glass window pane problem- noquacks General Discussion 3 01-31-2011 07:52 PM
Installing wall mount rack on a concrete wall? helpless handyman Building & Construction 5 08-20-2010 10:33 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
