Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-17-2009, 01:26 PM   #1
Question
Mirror Mirror on the Wall
I have a wall in my living room that is mirrored. I really like the effect of the mirrors (illusion of more room), but I do realize that it dates the house. Is there anything I could do to update these mirrors?
lkwilliams is offline   Reply With Quote
Old 07-17-2009, 04:20 PM   #2
long island, NY
honestly, probably not. However, that doesn't mean that there aren't other ways to visually increase the size of a room......
solid and light wall colors (no chair rail, patterns, or boarders). Light colored flooring.... if wood flooring, the planks should run in the same direction as the shorter walls.. this visually elongates them.
Have light colored and thin curtains that go from floor to ceiling.
furniture can also make a room look less cluttered and more spacious...
glass tables
smaller scaled furniture
low profile furniture (side board instead of tall china cabinet)
avoid bulky chairs or oversized china cabinets
hope this helps
diy'er on LI is offline   Reply With Quote
Old 07-20-2009, 12:23 AM   #3
Thanks diy'er on LI - those are some really great things to work with!!
Old 07-20-2009, 01:54 PM   #4
Stuck in the 70's
Blondesense's Avatar
You might get more response with more information (a pic would help). How big is the wall? How big is the mirror? Is the mirror one piece or those 12" squares?
I saw a pic somewhere. Someone took a bunch of 12" mirror tiles and used trim between and around them to give the impression of a latticed window. A narrow shelf was then added below as a sill.
Old 07-21-2009, 10:01 PM   #5
I do like mirrors for the same reason it cause this wide space feel. I have one facing the dining area and what i did to update? I repainted the wall with beige and it was as thought the whole dining area finally was awaken. Colors are the easiest to substitute and very fun to do too. Hope this helps
http://www.pestbomb.com/
heart08 is offline   Reply With Quote
Old 03-22-2011, 12:58 PM   #6
Many people like the look of a large mirror on the wall in their home or apartment. In addition to being useful to check out your style and appearance, many people believe that they can be effective in helping to make a small space look larger. It's important to be careful when hanging a mirror. A big glass mirror with a wooden frame is probably a lot heavier than the photos you normally hang on the wall.
You need to be a bit more careful when hanging it. Most photos can be hung with a single nail. Heavy mirrors should use a hook that connects to the wall, and ideally two or three hooks. Sometimes the hooks can lock in order to make sure that even a strong earthquake will not dislodge your mirrors and send them crashing to the floor.
Brian
http://miceexterminationforbeginners.blogspot.com/
freedomlover007 is offline   Reply With Quote
Old 04-01-2011, 04:07 AM   #7
I agree to diy'er on LI using a light color of curtains may help you..and avoid using big cabinets, and big tables is not good to put those things in your room
desiree_furman is offline   Reply With Quote
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 02:59 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
