-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Matching Ceiling Fans? (http://www.diychatroom.com/f50/matching-ceiling-fans-15742/)
fmfd35 01-17-2008 02:42 PM
Hello All! First Post!!
Question... My living room and dining room are open to each other. Combined approx 16'x32'. The dining area (which is actually used as a office/ work area) has a ceiling fan. I would like to add one to the living room where my lighting is terrible (2 lamps). Question is, how important is it that these two ceiling fans match or can I go with another more modern style? Current ceiling fan is the Hunter Summer Breeze #20540. Not exactly the most appealing fan out there. Funds not available for two new fans.
Thanks For Any Help!
fmfd35
mdancey 01-17-2008 04:28 PM
As they are open to each other it is important that they share some of the same elements. If the one you have is wood then get a wood one same wood tones. Also look for one that is the same size. If you don't like the one you have and think that you would change it later when funds do allow then buy what you want and when able replace the old one.
Are you putting in a fan for lighting reasons only? You do not have to have fans in both areas, you could just put up lighting. If you go this option I would look for lighting that has the same materials as the fan. Such as ....if the base of the fan is chrome or a nickel finish then buy a light fixture that is chrome or nickel.
Cheers
Mary
P.S. Welcome to the sight!!
AbSoluTc 01-25-2008 12:18 AM
Cheers
Mary
Pretty much nailed it. :)
Here is the thing with fans - they seem to have a new model every week. If you buy one and want another exactly like it - wait and buy them at the same time unless you know for a FACT that you can get it later.
If you really want one now, buy one and later on make sure the second fan has the same aspects as the first.
If light is what you really want, consider installing a light fixture. Fan lights are nothing to write home about.
kimberland30 01-25-2008 10:13 PM
I agree. Most ceiling fan lights only hold a 40-60 watt bulb, and that isn't going to add much light.
You could get 3-way bulbs (up to 150 watts) for your existing lamps (we have 30-75-150's in ours), or just install a light fixture as others have suggested.
