Mantle On Wall Made Entirely Of Brick - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-02-2013, 08:32 AM   #1
Rewards Points: 201
Mantle on wall made entirely of brick
Hi everyone. Below is a photo of our living room wall. It is entirely brick with a wood fireplace insert. It has a ledge along the bottom which is approximately 14" deep.
We want to build a mantle to surround the fireplace and mount our tv over top. We aren't sure how to build the mantle underneath the ledge. Should it extend below? Should it only extend to the ledge and leave the brick underneath the ledge as is?
If it matters we will be painting the brick (not sure on color/style yet).
Thanks for any insight!
NickWa is offline   Reply With Quote
Old 12-02-2013, 09:10 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
Having legs on the mantel is your preference. You can attach 2X4s to the brick and install the mantel over the 2Xs. Code in this area is, no wood shall be closer than 12 inches above fire box and 8 inches on each side of fire box, per inch of protrusion. This is code on a real fire place.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-04-2013, 01:05 PM   #3
Rewards Points: 274
I think mantle should be extending below.
alexjoe is offline   Reply With Quote
Repaired brick wall meets vinyl siding leak diynonstop Building & Construction 5 04-18-2013 02:43 PM
Capping a brick parapet wall jrschenck Roofing/Siding 2 08-21-2011 11:22 AM
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 06:46 AM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 08:07 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
