Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-12-2012, 07:42 PM   #1
Is the mantel shelf I installed too short?
Hi,
I just installed a mantel shelf and I am thinking it is too short. What do you think? Should it extend out more on the sides? I still need to stick the slate around it but I want to wait and see if I should work on the mantel some more before I do that. Is there is a rule about mantels being a certain length compared to the fireplace?
Thanks for your help!
Is the mantel shelf I installed too short?-fireplace2.jpg   Is the mantel shelf I installed too short?-fireplace1.jpg
guitar548 is offline   Reply With Quote
Old 11-12-2012, 08:28 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
To me it looks fine.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-12-2012, 11:36 PM   #3
sdsester's Avatar
Could stand to be wider on the bottom so it came the width of the fireplace but I would not sweat it!
sdsester is offline   Reply With Quote
Old 11-14-2012, 08:24 AM   #4
I think it's too low and needs to be raised up ten to twelve inches.
Two Knots is offline   Reply With Quote
Old 11-14-2012, 08:42 AM   #5
Took a look at mine. The bottom of my mantel extends 2 inches past the fire place opening. (it came with the house I did not build it)
retro is offline   Reply With Quote
Old 11-14-2012, 08:46 AM   #6
gregzoll's Avatar
Look right above it, there is a HDMI cable & electrical outlet. That would be why it is lower, so that they can hang a tv above it.
Old 11-14-2012, 09:04 AM   #7
oh, yes I see, I'm not a fan of tv's over fireplaces, especially stone
fireplaces, maybe that's why I didn't notice it. We have a stone fireplace
it's very bumpy, so it's hard to imagine a tv laying flat on the stone.
To the original poster, is there another place for the tv in the room?
Old 11-14-2012, 10:56 AM   #8
gregzoll's Avatar
It does not hang on the stone, but on a bracket. Some pwople want it that way, since their room layout may be screwed up, but also want the best of both, since they have the fireplace.
Old 11-19-2012, 02:57 AM   #9
I heard once a long time ago that the mantle should be 18" above the fireplace for safety reasons. I did that with mine and I think it looks surprising good. I would make the mantle a little wider.
mommywoman is offline   Reply With Quote
Old 11-19-2012, 02:42 PM   #10
Could you first build the fireplace, then build the mantle ( a little wider)
and then scribe the mantle to the stone?
That is the way we did our stone fireplace...this way you can experiment
with the height (by using 2 x 4's ) to see the desired height before
scribing the mantle.
On our stone FP the hearth is 11" high and the mantle is 24" above the
opening.
Your hearth is floor level, so you could go higher with the mantle
and still have room for the tv.
Twin Water Heaters Installed BigD9 Plumbing 6 04-08-2012 02:06 PM
Help! How do I reduce lateral sway or wobble in a shelf unit? sfsdfd Carpentry 9 07-15-2011 03:29 PM
how to build toy shelf near ceiling of kids room Kimmoski Carpentry 2 06-22-2011 08:22 AM
Adjustable Cabinet Shelf HPHulmeJr Carpentry 1 11-18-2010 11:59 AM
Floating Shelf - 32" TV sacman11 Carpentry 1 10-24-2010 09:19 AM
