Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-07-2009, 05:49 AM   #1
Looking to buy fire doors?
Can anybody suggest me from where should I buy fire doors?
Alex Harvwey is offline   Reply With Quote
Old 03-07-2009, 06:13 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
your best bet would be to go to your Lumber yard, they could also be ordered from your big box stores (HD Lowes) I personally would stay away from there, Good Luck BOB
Old 03-07-2009, 08:01 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are looking for "fire-rated doors" (i.e. - between garage and home), then Home Depot and Lowes carry them in stock. I believe they are 1 hour rated. Realize that these are comprised of the door, in the frame, as a fire-rated door is the whole door arrangement (not just the door slab/leaf).
If you are looking for a higher rated (90 minute + rating) fire door, then something like that would have to be ordered from the previously mentioned places.
Alternately, a high rated door system, may be in stock at a commercial supply house, that specializes in interior materials (like sheetorck, ceilings, steel frame and doors).
- Build Well -
Old 03-08-2009, 05:18 PM   #4
Drywall contractor
An option that may or may not be viable.... Locally, I buy commercially rated fire doors through Overhead Doors. They are an international company, known for residential garage doors/commercial "roll up" doors . Here in the Atlanta area they have a separate entity for any kind of "regular swing" fire rated door you need. The roll-up company (Yellow Pages) can get you to the commercial door branch if there is one locally. You can generally go get what you need directly from them if a drywall supply does not stock what you need and you don't want to wait.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
pocket doors ...how to make fire rated clasact Building & Construction 21 03-11-2011 05:46 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
