LED Transformer Questions - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-02-2013, 11:27 AM   #1
Rewards Points: 248
LED transformer questions
I am considering some under-cabinet LED lights based on recommendations I've received here. But I don't think it's feasible.
There is no outlet to plug the transformer into. That is an absolute given.
We have a 120V 14 AWG hot wire (black, white, ground) coming out through the wall directly through a hole in the 5/16" wooden apron at the bottom of the cabinets. Below the cabinets is a granite backsplash, full-height.
This 120V wire used to go directly into a fluorescent light. I can follow this 120V wire down into the basement directly below the kitchen and see where it runs along the floor rafters.
I know you wouldn't want to run high voltage over a thin wire, but is it possible for 14 AWG wire to carry 12VAC?
With a Class 1 transformer, could we do this in the basement:
120V 14 AWG wire -> transformer -> 12VAC over 14 AWG --> 1st LED
That is, basically wire the transformer in-line. Bbring 120V on 14 gauge into the transformer, and take 12VAC over 14 gauge out of the transformer up to the first LED, and there we switch over to low-voltage wire and daisy-chain additional LED units using the low-voltage wire?
I estimate the distance between the transformer in the basement and the first LED would be about 8 feet.
diy888 is offline   Reply With Quote
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
transformer questions Steelhead Electrical 8 10-25-2009 08:39 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
When a pole transformer goes bad Ultrarunner2017 Electrical 39 12-03-2008 09:44 PM
