-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   LED transformer questions (http://www.diychatroom.com/f50/led-transformer-questions-186357/)
diy888 09-02-2013 12:27 PM
I am considering some under-cabinet LED lights based on recommendations I've received here. But I don't think it's feasible.
There is no outlet to plug the transformer into. That is an absolute given.
We have a 120V 14 AWG hot wire (black, white, ground) coming out through the wall directly through a hole in the 5/16" wooden apron at the bottom of the cabinets. Below the cabinets is a granite backsplash, full-height.
This 120V wire used to go directly into a fluorescent light. I can follow this 120V wire down into the basement directly below the kitchen and see where it runs along the floor rafters.
I know you wouldn't want to run high voltage over a thin wire, but is it possible for 14 AWG wire to carry 12VAC?
With a Class 1 transformer, could we do this in the basement:
120V 14 AWG wire -> transformer -> 12VAC over 14 AWG --> 1st LED
That is, basically wire the transformer in-line. Bbring 120V on 14 gauge into the transformer, and take 12VAC over 14 gauge out of the transformer up to the first LED, and there we switch over to low-voltage wire and daisy-chain additional LED units using the low-voltage wire?
I estimate the distance between the transformer in the basement and the first LED would be about 8 feet.
