LCD TV Over Fireplace.. - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-06-2007, 09:31 AM   #1
Fire Fighter-
Klint's Avatar
LCD TV over Fireplace..
What have you all done with your Cable boxes, DVD, stereo and other componets when you hung your TV over the fire place? I have a little space to the left of my fireplace.. What kind of shelve can I buy, cheaper is better
Thanks,
Klint T.
Klint is offline   Reply With Quote
Old 08-06-2007, 09:10 PM   #2
Fire Fighter-
Klint's Avatar
I found a few but nothing like I want. I need a cabinet that will hold my Dvd, stereo and cable box that will hang on the wall. The thing that is getting me is I want the doors that slide back so they are hidden but I can close it offer when I need. Any help would be much appreciated.
Thanks,
Klint T.
Old 08-06-2007, 09:20 PM   #3
Rewards Points: 1,456
Klint,
Can you post a pic of what your situation looks like?
Lot's of possibilities, but I'd really need to see what's there to begin with....
ktkelly is offline   Reply With Quote
Old 08-10-2007, 11:59 PM   #4
Klint -
What is your budget? There are some nice vertical racks that should compliment your setup and accomodate the components you need to run your system.
John_In_PA is offline   Reply With Quote
Old 08-11-2007, 12:54 AM   #5
Fire Fighter-
Klint's Avatar
as cheap as I can get.
Thanks,
Klint T.
Old 09-04-2007, 05:50 PM   #6
jkchapp2
Is it possible to place the shelving behind the t.v. (hidden shelves), build a frame which holds your t.v. and place a hinge on the side? As long as it is not a woodburning fireplace, of course. How large of space on the side? Wood shelves from say, Home Depot, Lowe's, etc. using wood shelf brackets?
jkchapp2 is offline   Reply With Quote
Old 09-05-2007, 05:42 PM   #7
jkchapp2
Another option, if the wall you will be hanging the t.v. on, is drywall...place a hole in the drywall behind the t.v., snake the wires up/down to a hole at the bottom/side of the fireplace and place a cabinet with all electronic inside.
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
huge fireplace issues krynstar Painting 10 03-10-2007 07:41 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 11:12 AM
Water leaking over fireplace mmcginn2 General DIY Discussions 1 04-21-2006 12:42 AM
