Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-04-2012, 03:30 PM   #1
Layout advice needed
I am trying to decide what to do with a large chimney wall in the middle of my living/dining area. The living room currently doesn't get much light, and this would make the house much brighter. The chimney services 2 fireplaces, one in the living room and one in the dining room. This is overkill for me as I don't really care that much having even one fireplace, and the house is pretty small. The main reason I would keep at least one is for resale value.
The options I am thinking are - keep it as-is, remove half of the chimney and have a single 3-sided fireplace, and remove the chimney entirely and have no fireplace.
I modeled the three options and was wondering if anyone had opinions:
https://dl.dropbox.com/u/6880177/house2.jpg
https://dl.dropbox.com/u/6880177/house1.jpg
https://dl.dropbox.com/u/6880177/house0.jpg
wave9x is offline   Reply With Quote
Old 07-04-2012, 03:34 PM   #2
Something else I should mention, where I live it is no longer legal to build a wood-burning fireplace, so if I remove it entirely, it is gone forever. Also, the chimney cannot be moved and kept as wood-burning.
Old 07-04-2012, 09:14 PM   #3
creeper's Avatar
So where do you live? Half my neighbourhood still uses a wood burning fireplace as the main source of heat.
Hard to make a judgement on an unfamiliar area, but around here the three sided option would definitely be the most desirable in terms of resale value
creeper is offline   Reply With Quote
Old 07-04-2012, 10:31 PM   #4
I live in Northern CA, south of San Francisco (San Mateo). It doesn't get really cold here very often but there are nights in the winter when having a fire on is very nice.
I think I am leaning towards the 3 sided fireplace. It opens up the living room somewhat but I don't sacrifice the wood burning fireplace, so it seems the most practical.
I haven't been able to find many contemporary 3-sided wood burning fire places, it seems they are mostly gas. The wood-burning ones look a bit dated.
Old 07-04-2012, 10:45 PM   #5
Actually this one looks pretty nice, something like this but longer on the sides could work:
http://www.robeys.co.uk/product/rais..._sided_firebox
Old 07-04-2012, 11:09 PM   #6
Renovations contractor
Bonzai's Avatar
Try looking on houzz.com to find the sort of thing you like and there may well be product info to tell you where you can get it. I use this all the time to determine inspiration for my clients.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-05-2012, 09:22 AM   #7
sdsester's Avatar
Fireplaces sell houses even in Northern California. Mine in San Jose had a formal one in the dining room and a semi-circular one in the family room. Wood was never burned in the living room and only for a short period in the family room. I converted both to gas. They definitely helped sell the house for a tidy sum.
As for the layout options. I guess I like the three sided the best of what you showed. I might be tempted to make the fireplace longer and rather than gas logs do something more contemporary with crystal blocks and random looking flame.
sdsester is offline   Reply With Quote
Old 07-05-2012, 12:39 PM   #8
Do you think there is a significant difference in value between having a gas fireplace vs having a wood burning one?
Old 07-05-2012, 12:58 PM   #9
sdsester's Avatar
The nice thing about your situation is that currently you can claim to have wood burning fireplaces even if you were to convert them to some gas log set-up. The gas logs I put in were formal looking in the living room and I filled the base of the fireplace in the family room with sand and put a driftwood looking thing on it. The living room was painted white brick and I doubt it ever would have been used if wood burning was the only option.
I found the gas flames as relaxing/mesmorizing as a wood fire and it was certainly safer. I missed the crackling sound of sap exploding and the smell but you can buy stuff like "Campfire Memories" or cedar incense to compensate.
I suspect more and more places will be cracking down on burning wood for environmental reasons. I am not sure burning natural gas is that green long term either. Modern fireplaces are not usually designed for heating so much energy just gets sucked up the chimney including warm air in the room that gets drafted. At least with gas you can close the damper a bit.
Long winded way of saying I am not sure the answer to your question. A good friend of mine develops and sells high end real estate around you. He always has the fireplace going when showing a property. Home and hearth trick I guess. He also makes sure the kitchen has the aroma of fresh baked cookies too.
When I did intimate interior gardens people always wanted to incorporate fire and water features if they had the money.
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 03:38 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 02:02 AM
Buying a home - water softener advice needed before closing Hoops Plumbing 4 11-02-2011 09:40 AM
Advice needed for draintile under sidewalk dgbehrends Landscaping & Lawn Care 5 11-17-2009 01:03 AM
