Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-06-2012, 10:59 PM   #1
Laminate flooring as Wainscoting.
We are getting ready to start work on a restaurant and are looking for a wainscoting thats durable, easy to clean and install, we found a nice mahogany/cherry snap together laminate at a great price, competitive with most beadboard we have found, think it would work ok?
Harley02974 is offline   Reply With Quote
Old 07-06-2012, 11:05 PM   #2
yummy mummy's Avatar
I like the way you think! Most definintely you can use laminate flooring on walls.
I used laminate flooring on the walls in my basement to create a libraryish feel in a small office.
I think it looks great.
Check out my blog. I have a picture.
yummy mummy is offline   Reply With Quote
Old 07-06-2012, 11:13 PM   #3
How did you attach it to the walls? We are thinking construction adhesive plus nailing the baseboards and chair rails should be plenty.
Your office turned out great!
Old 07-07-2012, 12:28 AM   #4
Not so sure how that's goning to work out long term.
Laminite has to be able to expand and contract. If not it will buckle and cause the glue to reliece.
Read the directions on any laminite flooring, all will say to not face nail. Nailing into the groves counts as face nailing.
Old 07-07-2012, 11:17 AM   #5
Thanks Harley.
Originally when I renovated the basement I planned on drywalling the office area. So I had studed the whole office area with wood studs. I nailed the laminate boards in with finishing nails right into the studs.
You don't need that many nails, just so long as it holds up, because obviously you won't be walking on it.
Mine is in the basement and sometimes it get humid and the walls have not buckled whatsoever.
joecaption; I am no expert by any stretch of the imagination, and I would not nail the boards if I put them on the floor but for the walls it worked for me.
Good luck Harley. If yummy mummy can do it, you certainly can too.
Old 07-07-2012, 11:46 AM   #6
Thanks for the info! I think I will just drill a medium size hole top and bottom every few feet, use a small screw and large washer so it will still float, cover those with the baseboard and chair rail.
Old 07-07-2012, 04:01 PM   #7
sdsester's Avatar
I despise cheap laminate flooring and it tops my list even over cheap vinyl siding. I certainly would not spec it for walls and definitely not in a restaurant environment unless I was sure about the thickness of the laminate and its ability to stand up to cleaning, perhaps with health department mandated stuff or a steam cleaner?
Nothing shouts "I am vinyl!" like vinyl.
This is a case where you really have to check the material specs. I don't like it but do not hate nice laminates so much. I see people getting suckered though. Don't be one of them.
sdsester is online now   Reply With Quote
Old 07-07-2012, 08:29 PM   #8
MarginallyQualified
Indoor/outdoor carpet on walls can work well too.
TarheelTerp is online now   Reply With Quote
Old 07-13-2012, 08:47 AM   #9
DIY-er
I've actually used laminate on a ceiling in a residential kitchen. Just applied it the same way that you would on the floor, and it looks great. No problems after 4 years.
KevinPh is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
