Laminate Floor Color? Help! - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-22-2013, 03:02 PM   #1
Laminate floor color? Help!
Trying to determine what color I should consider putting in my condo. It's small so I know I want to stay away from anything too dark and I also know that upon install I want to put it down diagonally to create a sense of open space. That aside, I just need help determining what might be the best color given the current colors of everything else in the condo. Here are some pictures. I need to move on this quickly so fast responses from the time of post would be greatly appreciated!
Laminate floor color? Help!-cabinets-island-kitchen.jpg   Laminate floor color? Help!-granite.jpg   Laminate floor color? Help!-kitchen-backsplash-closeup.jpg   Laminate floor color? Help!-kitchen-backsplash.jpg   Laminate floor color? Help!-wall-color.jpg
JPhoenix is offline   Reply With Quote
Old 03-22-2013, 04:23 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Id do something close to the dark tan in the mosaic tile. Or match your cabinets. That cherry color would look cherry on your floor. Pun intended.
brockmiera is offline   Reply With Quote
Old 03-22-2013, 04:42 PM   #3
Rewards Points: 14,026
Laminite flooring on a diagonal
Good luck trying to install it that way.
Near impossable to lock it in at an angle like that.
Old 03-22-2013, 05:04 PM   #4
brockmiera's Avatar
I've never heard that diagonals make the room look bigger.
Old 03-25-2013, 04:32 PM   #5
Professional
UniqueWoodFloor's Avatar
I think you should consider a cherry color. It would bring some warmth to the room and serve as a focal point. American Cherry offers a very upscale look and feels warm on your feet. Look for an engineered American Cherry with a lock system.
UniqueWoodFloor is offline   Reply With Quote
Old 03-25-2013, 04:42 PM   #6
Laminite flooring will do nothing but lower the value of the home.
Engineered or prefinished hardwood will increase it.
Ever see an ad in the paper for a home saying new laminite flooring?
But there's lots of them saying hardwood floors through out.
Old 06-07-2013, 02:21 AM   #7
Try color which perfectly match your walls and ceiling. Remember, it should not be white and light color. According to Joecaption, you may also use laminate flooring. It’s a perfect and cheap way of flooring.
timkitchen is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 12:43 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
