Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-02-2009, 05:09 PM   #1
Default kitchen paint color advice
i'm having difficulty choosing a paint color to go with my kitchen backsplash (pic attached). i plan to renovate in a few years so don't want to change the tiles at this point.
i want to add some color, but nothing i've looked at seems to work with the retro tile, so i'm reluctantly thinking about a light cream. the cabinet handles are being changed to silver and i'm considering oak laminate flooring.
any advise?
abfab04 is offline   Reply With Quote
Old 07-03-2009, 07:15 AM   #2
If you are considering Oak laminate flooring, choose any color that is similar to that of white sand. will give you that woody structure of uniformity
lilypotter is offline   Reply With Quote
Old 07-03-2009, 02:58 PM   #3
what country are you located in? and are 48" entry doors the norm?
Jay123 is offline   Reply With Quote
Old 07-03-2009, 07:39 PM   #4
Haste Makes Waste
Was curious of the same....the countertop and cookstove look to be as high as the door.
As far as color, pale yellow or or a soft terracotta or peach color would look very nice with the existing colors in the room.
saggdevil is offline   Reply With Quote
Old 07-06-2009, 10:16 AM   #5
thank you for your suggestions. I ended up painting a light yellow which worked out well.
Its a standard size side door. There are a 3 steps down to landing, which doesn't show in the pic, making it look smaller!
Old 07-06-2009, 10:27 AM   #6
I thought you might be a family of hobbits
Old 07-13-2009, 04:16 AM   #7
I would really go with a buttery cream color and antique white, I know it sounds boring but it's a safe combination and it'll go with anything. You could use the fabric and accessories to accent. Good luck.
Last edited by AtlanticWBConst.; 07-13-2009 at 08:01 AM. Reason: SITE RULES VIOLATION: ADVERTISING LINKS REMOVED
frdsmth9 is offline   Reply With Quote
Old 08-19-2009, 04:11 PM   #8
Sephora's Avatar
OMG...I thought the same thing when I saw the door but then realized that there was prob a step-down to the door.
But anyways, did you put the backsplash up?
I would paint a similar color that is in the backsplash for the walls. New laminate flooring would look good.
Sephora is offline   Reply With Quote
More On This Topic
A glaze, which provides color and texture, is basically liquid glass the manufacturer sprays, pours, drops or silk screens onto the tile. They then bake or kiln fire the tiles to harden the glaze. Most ceramic tile is glazed, and with so many variations... Read More »
Hand painted decorative tiles add a special touch to many homes today. In a generation where home owners look for those little things that make their homes stand out from the rest, decorative tiles are a great way to accomplish that goal. Keep reading to... Read More »
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
One of the best changes or upgrades you can make to your home is adding or changing the tile in your kitchen or bathroom. Before you can begin this type of upgrade, you must first buy your tile. Read More »
The base of your mosaic is determined by your application. Since this mosaic is a kitchen splash, I decided to put the mosaic on the backer board that you put tile on to put a splash on a kitchen. And this is what the backer board looks like. You buy it... Read More »
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 06:57 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 13 09-29-2008 01:20 AM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 09:18 PM
Flat over Semi-Gloss dankreboot Painting 10 07-06-2008 12:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
