Kitchen Over-the-sink Light - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree1Likes
  • 1 Post By stick\shift
Old 12-27-2016, 01:00 PM   #1
Rewards Points: 14
Kitchen over-the-sink light
Our kitchen had a florescent fixture over the sink (had). We have replaced it with a fixture with 4 "globe" bulbs. Problem is the octagon box the the florescent was on is not centered.
So I'm wanting to replace the fixture with 2 to 4 hanging pendants. If I choose 4 pendants is there a controlling switch that will allow me to choose 2 bulbs or all 4 so I don't have to do major rewiring?
Sent from my SAMSUNG-SM-N900A using Tapatalk
ChuckTin is offline   Reply With Quote
Old 12-27-2016, 01:07 PM   #2
Rewards Points: 660
Re: Kitchen over-the-sink light
Since the drywall over the kitchen sink is seldom textured, my first thought would be to center the box.
With your proposal, it might depend more on the fixture than the switch.
Druidia likes this.
stick\shift is online now   Reply With Quote
Old 12-27-2016, 01:26 PM   #3
Rewards Points: 14
The kitchen has a Cathedral ceiling and the fixture is against the outer wall. To move the box would require tearing out and repatching a 2' by 3' drywall section. Not impossible but a PITA. Also I have to get all this past the she-who-must-be-obeyed. To facilitate that I need all the bits and pieces selected and laid out before hand.
I was envisioning 4 pendants on a sub frame (spanning three ceiling joists) but controlled from one switch. Switch postions would be Off, far light, center lights, all lights. Maybe I'm day- dreaming?
Old 12-27-2016, 01:32 PM   #4
Oso954's Avatar
Rewards Points: 1,110
Why not use a dimmer instead of the 2vs4 bulbs?
4bulbs at 50% is the same light level as two bulbs.
Oso954 is online now   Reply With Quote
Old 12-27-2016, 01:33 PM   #5
Rewards Points: 660
Ah, I forget about you guys who have to have someone else approve the plan
As I said, I think the fixture is going to be important, as the switch can't do anything special if there's just one switched wire going to the fixture in the first place. In other words, your fixture has to have different wires controlling the lights. That said, I could see four independent fixtures, two on one switch and two on another happening very easily, so it's possible you could find a three position switch to make that work.
Old 01-15-2017, 12:13 PM   #6
Rewards Points: 32
do you have any pictures???
yamaha6611 is offline   Reply With Quote
Old 01-15-2017, 02:14 PM   #7
Rewards Points: 14
The thing that sparked this question was a Web page that listed rotary switches for 110/120 vac (haven't seen _those in a coon's age and a half!, maybe more).
With one input feeding multiple outputs that might be an answer.
Pictures? I can do that.
Overall.
Detail
Maybe those'll come thru.
Old 01-15-2017, 02:57 PM   #8
Rewards Points: 32
i wouldnt hang pendants in front of that window.. it would look wierd. you have a nice fixture on the left... just install another same exact one on the right.. pop a hole in that drywall, run a 2ft piece of romex over there and wire it in... then replace the switch that turns it on with a dimmer, now youll have lighting from both sides, 8 bulbs, and control of how bright it is!
Replace kitchen light over sink one eye guy Electrical 5 03-28-2015 06:53 PM
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Kitchen sink, stainless undermount or Trugranite undermount? DIY-Her Kitchen & Bath Remodeling 4 05-10-2012 12:18 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 12:27 PM
